Mass Ownage
- 0
- 0
- sulphur, LA
I did a couple searches and wasn't able to find anything on this. I am Bobbing my truck. I have the springs mounted and just got my u-bolts so i can mount the axle. Looking at the axle housing, I don't see where the alignment pins will be of much use when using the M105 springs. This is just at first glance, I wanted to get some info from you guys before I got started. Are most of you not using the pins? I know I have to notch my lift block for the seam on the center of the housing. I was trying to figure the easiest way to ensure the axle is centered left to right. I'm assuming its just the good old tape measurer and a sharpie... Thanks for your input guys.
