2011 vin info thread
CARNAC
The Envelope Please.
617
Corpus Christi, TX
Greetings, Carnac and thanks in advance for any info you can provide on my 1969 Kaiser-Jeep M35a2 (no winch):
Serial No: 052511068
Registration No: 04F73370
NSN: 23200771616
I purchased the truck recently here in Florida, but the S-97 shows the original owner to be Alfa Heaven in Aniwa, WI
No bumper numbers on truck currently.
Organization:32ND EN CO HHC Location:ONALASKA WI Nomenclature:
TRUCK CARGO 2-1/2T Model:
M35A2 NSN:
2320000771616 Serial Number:
52511068 Registration Number:
4F73370 Year of Mfg:
1970 Manufacturer:
65909 Usage Miles: 31380
Sep 98
CARNAC
617
Corpus Christi, TX
Thanks for doing this for everybody, I'm sure it takes some time to find all this stuff
I have 2 that i am curious about.
Jeep Kaiser M35A2 WO/W [titled as 1970]
Vin- 032526424
Reg-----
NSN 23200771616
Private seller
Contract # DAAE 0668C0007
53,000 miles
Engine date 05/85 LDT4651C
rear bumper marking. 43BG over 118BN and 215P over 3
The following is a parts truck, only have the frame up, and dash. Vin # is same on dash as is stamped on frame. If odometer and hour meter are correct, this unit had almost no miles or hours on it.
General products Jeep Corp M35A2 W/W
vin 053911509
reg ???
NSN ???
Contract # ???
Came with above truck, pvt seller
Miles 248. Hours 2.8
Engine LDT4651D date 10/87
Thanks again.
Organization:1ST BN 109TH FIELD ARTILLERY SVC BTRY Location:WILKES BA
PA
Nomenclature:
M35A2 NSN:
32526424 Registration Number:
4A40970 Year of Mfg:
1970 Manufacturer:
65909 Usage Miles: 50809
Sep 2010
Organization:HHC, 56TH BRIGADE COMBAT TEAM, 28TH INFANTRY DIVISION Location:WILLOW GROVE
PA
Nomenclature:
M35A2 W/W NSN:
2320000771617 Serial Number:
53911509 Registration Number:
4G44371 Year of Mfg:
1971 Usage Miles: 37140
Apr2009
CARNAC
617
Corpus Christi, TX
OK, that does it. If additional requests come in, I'll complete them when I have time. Otherwise, I will be working my butt off until mid-September.
USAFSS-ColdWarrior
Chaplain
5,679
Until we meet again....
Happy Trails to you.....
[media]http://www.youtube.com/watch?v=XcYsO890YJY[/media]
BTW: If you know that you'll be "working my butt off", you might prepare in advance for your pants no longer fitting properly. Most garments will be able to be altered, but your skin-tight double-knit leisure suit will probably need MAJOR MODIFICATION.... Is that why they make those "A$$-less Leather Chaps" that Wreckerman and PapaBear are always drooling over???
John S-B
955
Ostrander, Ohio
OK Carnac, this is what I have for you;
M35A2 Wo/W was told it may be a '74
A.) VIN: 04A87031
B.) REG: Unknown
C.) NSN: 2320000771616
D.) GL Possibly somewhere in Indiana (From what I was told, bought from third owner-no title. Bought near Hamilton Oh.)
E.) Pass. side of truck illegible-had been stenciled several times. Possibly had ENG on it. Other side had C-4
Thanks for your work!
Chief_919
100
Western NC
A.) VIN:04A87031
B.) REG: Unknown
04AXXX is the registration #, but I can't find a match. What is stamped on the frame?
Chief_919
100
Western NC
Where on the frame do I need to look? I'll run out and find it. Sorry for the SNAFU.
Drivers side, under the front fender behind the front wheel. The actual VIN is stamped there, but likely under a lot of paint so you might have to do some scraping.
John S-B
955
Ostrander, Ohio
Okay, I found 0525 17738. I noticed that same # was also on the ID tag under the contract # block, but I just assumed it was the number that a block of trucks were ordered under.
Chief_919
100
Western NC
Organization: W0XY, W0XY SUPPLY DIV
Nomenclature: TRUCK CARGO 2-1/2T
Model: M35A2
NSN: 2320000771616
Serial Number: 52517738
Registration Number: 4A83071
Year of Mfg: 1971
Manufacturer: 65909
This shows it was a USAR truck, turned it at Ft McCoy. Before or above the ENG on the bumper should be a number that will tell you what Engineer battalion it belonged to.
F18hornetM
10
Ocean City, Md
Thanks for all the info, as you requested I made a donatation to the wounded warrior fund which is the least we can do for those guys. Thanks again!!
BadMastard
Duvall, Wa.
Oh amazing carnac, can you answer this riddle?
Vin- 503995
Reg- unk
NSN - 2320-01-383-2050
Purchased- GL Nellis NV
bumpers- unk- paint is tougher than sand paper
rebuild year -1998
Does your crystal ball also tell you the serial numbers that were used to rebuild the A3? Or where I might find them?
Many thanks
Chief_919
100
Western NC
Vin- 503995
Reg- unk
rebuild year -1998
Many thanks
This truck is odd... 2 entires for that SN, one for a M44A3 and one for an M35A3.....
Organization: 0127, 127TH MILITARY POLICE COMPANY
Model: M44A3
NSN: 2320013832047
Serial Number: 503995
Registration Number: NK0K3G
Usage Miles: 19905
Organization: W6KE, ECS 171 BARSTOW CA FACID CA 196
Model: M35A3C
NSN: 2320013832050
Registration Number: NK0KEP
Usage Miles: 19905
BadMastard
Duvall, Wa.
That's interesting- think it could be both, being "swapped" from one unit to another? The interesting part is the mileage on the truck was about 7K on the speedo, and it seems to have about that much wear on everything.
Model: M44A3
NSN: 2320013832047
Usage Miles: 19905
Model: M35A3C
NSN: 2320013832050
Usage Miles: 19905
USAFSS-ColdWarrior
Chaplain
5,679
With the USAGE MILES being IDENTICAL at 19905, I'm guessing that it's only DISGUISED as an M35A3 and is really still an M44 under-cover for the MP's where it's actually assigned. You got a "secret agent" truck there ! ! !
Is it wearing Groucho Glasses and a Mustache????
Hi CARNAC: Not sure if you or others can help with this:
The option code sticker vin (in the glovebox) doesn't match the vin plates riveted to the truck. No surprise - someone likely switched the glove box. But I would like to find out the history (and also the actual option codes for a M1031) of my truck...
VIN=1GBHD34J9GF434635
apm80814
Divide Co
Hey CARNAC:
Here is the info on my 1970 M35A2 WO/W:
a. 052517122
b. 04N14470
c. 2320000771616
d. Private sale in IA. Believe it to be a former IA NG truck.
e. UNK
The IA title lists the VIN as the registration number. I am not sure how much of a problem this is going to be when I go to register it in CO next week. I am hoping that when I get the VIN verified and explain to the DMV staff that they can correst this without too much hassle. Any insight as to an approach to rectify the incorrectly listed VIN on the title would be appreciated.
Thanks
Chief_919
100
Western NC
No data.
