EODTECH90
- 0
- 0
- Hinesville,GA
is the 700r4 swap a direct one or do i need stuff? like drive shafts
Driveshafts will fit.is the 700r4 swap a direct one or do i need stuff? like drive shafts
Unless you know that the glow plugs are brand new, I'd just get new ones. They are easy to do while you have the engine out and much more difficult with the engine in.
To do a side mount turbo wouldn't be a bad job, couldn't you just use your J code 6.2 heads (with 6.5 head gaskets) and go to a junk yard and find the "f" code intake manifold (remember, it comes in 2 pieces) and make it work?
That seems like it would be significantly easier.
do you have pics of this swap, could you also put up a parts list? PleeeeeeeezDriveshafts will fit.
You will need a 208 Transfer case that came from behind a 700r4 or Th350 for the output shaft to fit, the TV cable and a TV cable pracket for a 6.2.
That said a 700r4 isn't much of an advantage in a 1009 with the 3.08 gears.
i dont think its gonna be that bad, im pretty excited to get this thing done i just gotta get it runnin!have fun welding the firewall.
