Short list: Front main seal, harmonic balancer, rear main seal, reseal pan, reseal timing cover, reseal valve covers, oil cooler lines, exhaust manifold gaskets, glow plugs, lower radiator hose, coolant temperature sensor, radiator petcock, transmission output shaft seal, R&R all rubber fuel lines, fuel filter, weld up cracks in fan shroud, doghead mod, HD v-belts, coolant, oil and filter, reseal front diff, alignment.
I was just going to find the hemorrhagic oil leak and fix it. Things escalated. I'm sure there's more crap in my parts bin I've forgotten about. We'll see what else comes up while I'm in there. Great time to strip and refinish all that tin, but I'm lazy and this is a driver. Call it patina. I just don't know how I'll be able to trust that there are any fluids in it when it stops marking its spot.
