Seems like this is turning into a build thread.
RattleSnack
Ford City, PA
If anybody wanted to try those 1/2" green belts, now is the time.
That's actually where I bought mine....pretty hard to beat that price!
I've probabably put about 400+ miles on my truck since I posted my pulley and belt upgrade....
https://www.steelsoldiers.com/threa...ay-lately-part-2.107203/page-485#post-2608090
...and so far, it's been working great....no belt squeal whatsoever. I'm definitely glad I did this upgrade. Just as a comparison, last year I put on all new regular (black) 3/8" Gates belts. They worked good at first, but it wasn't long before they started to squeal again. I'd tighten up the belts up....it would go away for a while....then the squeal would come back. I probably re-tightened them 4 or 5 times. You could tell the belts were wearing because you could see they were getting narrower, and the alternators would have black belt residue all over them.
Definitely recommend doing this.
CARC686
655
New Mexico
Hard to find anything reasonably priced anymore. My belts are older than my ownership of the truck. Since they have to come off anyway while I deal with my reward for putting mechanic in a bottle in my engine, figured I'd replace them too. Thank you for the reference image. I had saved it and forgot where it came from.
Sharecropper
1,116
Paris KY
Squealing belts are a positive indicator of pulley misalignment, period. The squeal occurs when a belt enters and exits a pulley at a slight angle, so slight that the eye cannot detect the misalignment. If a belt is misaligned with a pulley, it will not matter which brand of belt you buy, they all will squeal and all will eventually wear out. An old-timer aircraft mechanic taught me this back in 1985 when I purchased a brand new '85 GMC K30 Diesel and had a squealing belt. He determined that the thin alternator belt tension bracket that GM used on that engine was slightly bent from the factory. After straightening the bracket and verifying all pulley alignments, not only did the squeal disappear, but the OEM belts lasted through my sale of the truck in 1995. My advice on this forum is - align the pulleys and be done with squealing & short-life belts. I posted details of aligning the pulleys on my P400 engine here - https://www.steelsoldiers.com/threads/squealing-belts-and-how-to-fix-them.189721/ .
Hope this helps.
CARC686
655
New Mexico
In the process of pulling the damper, I noticed I'm going to have the engine pulled down to a short block fixing leaks before I'm done. If it's rubber, it's ruined. Yeehaw.
CARC686
655
New Mexico
Is it true you can cut the rubber off the oil cooler lines and replace them with clamped 1/2" hyd hose? OEM has been discontinued for 16 years.
deank
561
Inverness, Florida
It should not be any different than having new A/C lines or power steering hoses made. Cut off the rubber lines and have napa custom clamp new hoses on.
CARC686
655
New Mexico
I read in an old post that the hard lines on the ends are barbed and you can DIY it. No harm in giving it a try. Either way, it's getting dealt with.
CARC686
655
New Mexico
Short list: Front main seal, harmonic balancer, rear main seal, reseal pan, reseal timing cover, reseal valve covers, oil cooler lines, exhaust manifold gaskets, glow plugs, lower radiator hose, coolant temperature sensor, radiator petcock, transmission output shaft seal, R&R all rubber fuel lines, fuel filter, weld up cracks in fan shroud, doghead mod, HD v-belts, coolant, oil and filter, reseal front diff, alignment.
I was just going to find the hemorrhagic oil leak and fix it. Things escalated. I'm sure there's more crap in my parts bin I've forgotten about. We'll see what else comes up while I'm in there. Great time to strip and refinish all that tin, but I'm lazy and this is a driver. Call it patina. I just don't know how I'll be able to trust that there are any fluids in it when it stops marking its spot.
CARC686
655
New Mexico
If they keep appreciating at this rate, it'll pay for the fact that I've had to replace everything on it.
