Another Ahab
- 4,942
- 113
- Alexandria, VA
Wow. Unbelievable!The rainbow was amazing, a rare occurrence. A couple more shots of it
Update on the LMTV cab swap: the cab is bolted down properly. Back-of-cab hooks are adjusted but I’ve got work to do on the cab latch. Good news and bad news, good first: after a week of troubleshooting I got Goliath to start and run, only the fuel gauge inop so far, probably connector. Bad news: spent a week troubleshooting “failure to start” problem. Between the -20-1 and several contributors here, found the problem. Somewhere between pin 87 of relay K1 and TL33 on the Aux Starter Relay there is an open connection. Absolutely everything else tests good including oil pressure switch, trans control module and VIM, relays, circuit breakers, wires, grounds, etc. I need to check the back of the PDP and make sure that socket is ok but otherwise, I’m much happier. Long road to “complete” but this is the biggest and toughest hurdle.
Will start another post about the broken wire…
Am doing the Snoopy “Happy Dance”. Am tired too…
Thx all!
A lesson from the Stoics of Ancient Rome:Actually, in deciphering the electrical schematics, both the fuel quantity wire from the sender to the gauge as well as the below wire from K1 to the Aux Starter Relay run through P43 under the main dash panel. I'm going to start there and do continuity checks both directions from there. Stupid me, it may be unplugged from troubleshooting this problem initially. Would be just my luck.
More to come...
- Laugh WITH the Gods, while they are laughing at you
Because there's plain nothing like a good laugh!
I'm getting more convinced by the day I need these, How's the low-end power feel. I'm worried it will hurt my towing abilities.This weekend I installed the Eco Hubs on my 1078. They sounded a little too good to be true, but Ronmar said they were worth it so I bought them. They are unbelievable. I have only driven about 30 minutes with them so far, but I cannot believe the difference. I pushed it up to about 65mph (as fast as I dared to go) and it was still in 6th gear. It would do 40 in 4th gear. I brought my wife for a drive and at 60mph I was able to talk to her in a normal voice. I coasted down a hill and it actually picked up speed. It is truly a different truck. It is, without a doubt, the best money I have spent on my truck to date.
I am afraid I don't know. Others who have done it say not much is lost, but I don't tow much.I'm getting more convinced by the day I need these, How's the low-end power feel. I'm worried it will hurt my towing abilities.
Towing what? With which engine at what power?I'm getting more convinced by the day I need these, How's the low-end power feel. I'm worried it will hurt my towing abilities.
3.90's?We don't tow much, though off road we lose traction first, and notice no loss in power. We love cruising at 60mph in 6th gear at 1,500rpm—
