srodocker
- 69
- 48
- Lacey, Washington
hehehe.
Go ahead and bring the trailer, I've got plenty of wire to rewire it. if anyone has a receptacle from the back end of an MV I can fab up an adapter for a civilian rig.Then I'll just need the connector to change out. I was going to change all the wiring out, just because it's kinda old, since 1990, at least, but if it's still good, why change a good thing.
So did anyone come up with an answer about the wheels?
Or should I post elsewhere?
oh i know about the 3-4 shift. funky, but I have driven them beforeAlways fun to see a noob try to shift a deuce from 3rd to 4th gear.![]()
Here's my nickles worth ----I'll dig the one out that I already have. The trailer light kit. Old stock wire... Gives me the shivers just thinking about it...
I wouldn't mind using the stock lights, just because they look so much better than after market stuff. Need to get some 12v LED bulbs for them though.
Then figure out how to put a light on the plate...
Unless it's mine... Try that trick and you get 5th gear...oh i know about the 3-4 shift. funky, but I have driven them before![]()
The data plate won't help either as I swapped in a direct drive for the tires...
I may have a connector that came off a CUCV which just had small gage wires and a weatherpack on it - I'll dig around tonight...
Matt
There's a seller on ebay selling adapters if you were to want to go that route, but wants $125.00 p/unit. Rather excessive. We can do one for far less.
Has the trailer been connected to a Mil Veh to insure all the lights function as designed yet? Very important.
Are the lights on it now the old style round shape, or the newer composite oval shape with the large red lens? Also important if converting to LEDs.
There's no real need for a plate light, as it wasn't made with one. There wasn't one on the Deuce and 105 I had, nor one on the 5 ton or M101CDN we have now and there's never been a problem with the Constabulary. I've never heard of anybody else being "talked to" about it either.
Unless your trailer's been a desert climate most of the time, the wiring should be okay. The 105 was a '53, and only needed a couple wires replaced due to a branch snagging them. It's usually the rubber coupler coverings that dry, crack and go bad.
The female, or vehicle mounted plug could most likely be had at Brads. Maybe somebody could pick one up before the 12th. Be sure there's at least 4 inches of wire to work with.
If you go to ebay motors, and look in military parts, or enter military LED, there are some tail light facings being sold for $30.00 per unit. The item number is 170591894392. The sellers user name is Bronco_buddy. They're desert tan, but can be masked and painted to match. If you convert to them, the stock lights will need to have to have the existing innards completely removed. (I did this with my 5 ton, and they work great.)
Or, to convert to 12 v, pull the 24v bulbs. Take them the local parts house and get the 12v equivalent. This was done to our M101CDN jeep tlr we pull behind the Blazer.
Bring along two small unopened tubes (one or 2 oz) of silicone, a can of liquid tape, or a can of black "Plasti- Dip" (hard to find, but Lowes has it in the spray paint rack) and at least 4 ea 1/2 or 1" paint brushes, along with your wire and connectors. I'll show you how to do the connections so they'll never leak. Bring wire ties (at least 8 inches, preferably 14 inches) and a couple rolls of high quality black tape also.
14ga wire will be more than adequate to make the adapter. Better yet, if you have or can get a pigtail (the coiled cable that goes from a semi tractor to the trailer) bring that. If the plugs are messed up that's okay. They'll be chucked anyway, and replaced with what you're putting on.
I'll bring a test light, crimpers, a multi meter, jumper wires and such.
See ya on the 12th.
HAhahaha, well that would throw me. but that's a good idea when going to the oversized tires.Unless it's mine... Try that trick and you get 5th gear...
Matt
