2011 vin info thread
CARNAC
The Envelope Please.
698
Corpus Christi, TX
CARNAC thank you for doing this for us mv owners! I've been wanting to know this info about my truck for ahwile now.
1987 M1028
VIN 1GCHD34J1HF310548
REG CT8224
NSN 2320010907895
Organization:135TH SIGNAL BN CO A Location:KANSAS CTY
MO
Nomenclature:
TRUCK CARGO 1-1/4T Model:
M1028 NSN:
2320011275077 Serial Number:
J1HF310548 Registration Number:
NG2S1M Year of Mfg:
1987 Manufacturer:
93219 Contract Number:
DAAE07-82-C-4060
Usage Miles: 17845
Jul 91
M35A2-AZ
426
Tonopah, AZ
Carnac,
Thanks for the assistance and help!!!
M35A3 wo/w
AM General
a. 500601 same as on frame
b. DDAE0793CR110
c. 2320013832047
d. Barstow, ca
e. Driver side F104 3 pass side NCB07
In side glove box # NCB07
I found some paper work in the truck that it was posted at a Utah NG post.
Also saw something about being in MI.
Thanks!!![thumbzup]
Nickaru
Lancaster, CA
M1008 info
CARNAC, thank you for doing this! I've always been interested to know more about my truck.
1984 M1008
VIN 1GCGD34J3EF378468
REG: I don't know
NSN: 2320011236827
Bought from: Private party
Bumper tag: AZ TMP 18
Donation made a few weeks ago.
Lawrence of Arabia
Howell MI
1971 Am General 5Ton M816 Wrecker
Bought from GL
Recovered from Wright Patterson
VIN or S/N: 06A91971C1270799
NSN: 23200510489
Service No: 8736857
Miles: 38,503
Thanks for any help
ecupirate
Clinton, NC
M101A2
a. Serial Number (VIN number) 157 (yes it is super short but it is on both data plates???)
b. Registration Number -----unknown
c. NSN without dashes -----2330013725641 -body 2330011018434 -frame
d. Where you bought it ------Ft. Meade
e. Bumper numbers if you can legibly read them ( 807 MDSC 807 MED BDE 629 FST T-6)
stancanpara
Montpelier VA
I'm feeling a little stupid here...
I have done MANY searches trying to find the "Correct" information needed.... Can't be sure I've found the right data...
I have an M275 Road Tractor. (This was my FIRST MV) Some years ago (about 8 or 9... I can't remember 'exactly' ) I found it in a back lot of a sawmill under some logs and it had some trees growing up through it... They said it was purchased years ago, no clue when or where, but that it had sat in THAT spot for at LEAST the last 10 to 15 years... Got it out and though it is is in terrible shape, it does have a hard top and after minimal clean up, it RUNS..
The entire truck was painted white and I was told that that's the way it was painted when they got it.. after much pressure washing and a little sanding, I was able to see that the hood was at one time stenciled US ARMY (and still is under some coats of paint) but don't see any other numbers there... The front bumper was torn up, with both sides broken off... One piece was inside the truck and I found the other piece not too far from where the truck was sitting...any numbers etc that may have been on them are gone...
I was trying to get my data numbers together for you to see if any history on it can be found, but when I went to enter the numbers, I realized that what I had didn't match up to what is very specifically required...
Not sure exactly which numbers are correct for your use...??? NSN what ?
I was HOPING someone else here had gone through CARNAC with their own M-275 before and could help me out but after doing a boatload of searches have come up with little...
The motor is an LD-465-1 and it has a turbo...
On the dash, it shows
Truck, Tractor, 2 1/2 Ton, 6x6 Multifuel M275
Stock No 2320-446-2479
Ser. No. M275
Mfr. Ser. No.165134 Model TK-D-42
Cont. No. FEB YR. MFD. 1964
DA-20-018-AMC-0398T
On the drivers side frame to the front of the axle is stamped 68 92L 10 32
On the drivers side frame to the rear of the axle is stamped 165134
So I am presuming that the Mfr Ser No is the VIN since it is stamped on the frame?
It was also recommended to me that the Stock No would be the NSN if I added two 0s between the 2320 and 446...? The plate shows 2320-446-2479 but I was 'informed' that it 'should' be 2320-00-446-2479???
So here goes my best effort at giving you what you require...
a. Serial Number (VIN number) ------165134
b. Registration Number ----don't know
c. NSN without dashes ----- 23204462479 or 2320004462479
d. Where you bought it Found it off Route 1, 11 mines north of Ashland Virginia
e. Bumper numbers if you can legibly read them.. none
Thanks for anything you can find![thumbzup]
ratspawn
Boulder City, NV
Thanks for what you do CARNAC. My information follows:
1986 M1009
a. (VIN) 1G8ED18J4GF141247
b. (Reg #) NF0H99
c. (NSN) 2320011232665
d. Recovered from Nellis AFB, NV
e. (Bumper numbers) Multiple, please see below.
Ancillary information: I don’t know if any of this is helpful at all but I thought I would include them since I can read them.
Bumper, rear drivers side and both sides of front, most recent: 913BDE
Bumper, rear passenger side, most recent: C5133
Bumper, rear drivers side, original? (in CARC): 124CR373NH
At the top of each of the four wheel wells: TP-35 (the dash literally stenciled on)
In the door frame, an Army reserve inventory sticker: ECS170000002105
Thanks again, and I hope I didn’t bombard you with meaningless numbers. Again, it’s just all the stuff i could read.
ryker725
Luling, La.
Mine
1967 Kaiser Jeep M35A2
A. 0022518490
B. Unknown
C. Not sure what this is, but got service number 4L7508 off of the data plate
D. Camp Shelby, Mississippi
E. MS 168 890
65 m151a1
Geronimo, OK.
INFO on a DJ5F for a friend
Carnac
A buddy of mine is not a member of this site and trying to find info for him that one time the Army did own and sold this vehicle. It is vage on the info I have at this point but I requested more info from him if possible.
DJ5F JEEP, LEFT HAND DRIVE.
A. DJ5F1000031
B. CF0123
C. UNKNOWN (pending)
D. UNKNOWN (pending)
E. UNKNOWN (pending)
Thanks Joe
P.S. I'm sure he will make a donation as well
CARNAC
698
Corpus Christi, TX
Carnac,
M35A3 wo/w
AM General
b. DDAE0793CR110
c. 2320013832047
d. Barstow, ca
Thanks!!![thumbzup]
Organization:213TH SUPPORT COMPANY Location:ST GEORGE
UT
Nomenclature:
TRUCK CARGO 2-1/2T Model:
M44A3 NSN:
2320013832047 Serial Number:
500601 Registration Number:
NK0G11 Year of Mfg:
1996 Usage Miles: 1728
Sep 2010
CARNAC
698
Corpus Christi, TX
A. 0022518490
B. Unknown
E. MS 168 890
Organization:HHD, 112TH MILITARY POLICE BATTALION Location:CANTON
MS
Nomenclature:
M35A2 NSN:
2320000771616 Serial Number:
22518490 Registration Number:
4L7508 Year of Mfg:
1967 Manufacturer:
65909 :Usage Miles: 18892
In Sep 91 it was transferred to the 106th Support Battalion in Montecello, MS.
CARNAC
698
Corpus Christi, TX
Carnac
A. DJ5F1000031
B. CF0123
Thanks Joe
Think this maybe it.
Organization:ARNG TRAINING SITE CAMP SHELBY Location:CP SHELBY
MS
Nomenclature:
TRK UTIL (1/2T-4X2) Model:
3200GVW NSN:
2320010907826 Serial Number:
1000031 Registration Number:
CF0123 Year of Mfg:
1978 Manufacturer:
65909 Contract Number:
GS00S56626
Aug 91
CARNAC
698
Corpus Christi, TX
1984 M1008
REG: I don't know
NSN: 2320011236827
Organization:1120
Unit Ident Code:
WVMXAA
Nomenclature:
M1008 W/E NSN:
2320011236827 Serial Number:
J3EF378468 Registration Number:
NG1AGD Year of Mfg:
1984 Manufacturer:
DAAE07-82-C-4060
Usage Miles: 59508
Sep 05
Unit information is sketchy obviously. The unit code is included. No other info available.
CARNAC
698
Corpus Christi, TX
M101A2
Organization:629TH MEDICAL DETACHMENT Location:BLACKLICK
OH
Nomenclature:
TRLR CARGO (3/4T) Model:
M101A3 NSN:
2330013725641 Serial Number:
157 Registration Number:
NW0W0N Year of Mfg:
1991
Oct 10
This is a Forward Surgical Team (FST) also known as a fast team. These are a team of 20 docs, nurses, and medics that travel around in 6 HMMWVs with trailers and do true meatball surgery on the front lines. IMHO the bravest of the brave for non-SF medical folks and the tip of the spear. As an infantry guy, I'd rather have had a fast team 100 yds behind me than the best equipped hospital 20 miles down the road. I digressed.
CARNAC
698
Corpus Christi, TX
1971 General Products M35a2 w/w
VIN: 04C68171053911671
Registration: Unknown
NSN: 2320000771617
Bought at Fort Indiantown Gap
Thanks Carnac
Organization:103D ENGINEER BATTALION Location:PHILADELP
PA
Nomenclature:
M35A2 W/W NSN:
2320000771617 Serial Number:
53911671 Registration Number:
4G68171 Year of Mfg:
1971 Manufacturer:
65909 Usage Miles: 15544
Aug 98
