2016 la rally swap, buy, sell, wanted tread
juanprado
3,157
Metairie/La (N'awlins)
I have:
3/4 tow bar pins
nhc250 water pump mounting plate gasket and water pump o ring
used m101 shocks
m923 spare tire carrier for 1100-20
fmtv wheel with ctis, o ring and bead lock $75
pair 3/4 tow bar feet for square tube tow bar or Ibes tek (use with tan biscuits) with both sets of pins 1-1/2 & 3/4 $100
Wife is very motivated for me to sell. Please help me ;-)
Mich xzl 3958520 holds air maybe 30% for a good spare $35 have 2
Mich xzl 16-20 85% tread- had hole in middle of tread with a small bolt can be patched easily, sidewall curb rash, good for spare or rear tire $50
900x20 on 6 lug rims 75% no leaks $60 have 2 SOLD
free pay it forward 1100 ndt on 5 ton rim
Trailboss
140
Norwood LA
I've got some more stuff I need to move. For the generators, let me know if you're interested so I can make sure they are running before I bring them down on Friday.
Singletree/Whiffletree that allows a wrecker hook to attach to the top of a truck's bumper. $65
Axle clamps have some rust, but fully functional $40 for the pair
MEP002A 5KW generator, around 2000 hrs. Has only been run under load for several 20 minute periods. If I bring it, I can put it under 4KW load to demonstrate. $1500 sold.
MEP005A 10KW generator around 200 hrs. Has only been run under load for 20 minute periods. If I bring it, I can put it under 4KW load to demonstrate. $2800
goldneagle
1,471
Slidell, LA
I am interested in the 5KW MEP 002A generator.
Csm Davis
403
Hattiesburg, Mississippi
I am going to sell the Michelin XZL tires and wheels of of my M931A2 they have 3000 miles on them and we're new when the truck was rebuilt in 2012. They have never sat flat and are in excellent shape. 350 each
sent from my decrepit fingers
HanksDeuce
263
Prairieville, LA
Anybody got a pair of cab pull handles for climbing in the cab of a M35A2? Mine have seen better days.
This is the handle on each side of the cab just beside the door handle.
Csm Davis
403
If they are the same as the ones on a 939 I can get you some when I get back home and just mail them to you. How's 20 plus postage?
goldneagle
1,471
Slidell, LA
I will be bringing some wrecker vise mounting plates. Also bringing sample of the underbed truck boxes and Kipper Mechanic's tool kits. I also have 1 driver's side door for M35 and 5 ton trucks in very good condition. I also have 9.00-20 and 11.00-20 NDT NOS tires. I have 9.00-16 Superlugs NOS, HMMWV tires, 10.00-20 tires.
