dabtl
- 7
- 38
- Denton, Texas
That leak does not look so bad. Perhaps it will heal itself? If not, perhaps it is not fatal?
More info on these?gm uses sealing pelets to stop leaks like this they have service bullitins on this . they work really good on cases like this . they come three to a pack it takes three to seal up one northstar motor. the deuce you would need 6-8 to do the job they are a permant fix i would put them in before retorquing the head .that way it will fill the gap the retorquing would lock it in
It has the tabs, sooooo, I'm assuming it's a new style head gasket?And another thought is it an old style head gasket or new style? If it's the old style it might be a precurser to failure, on the old style I'll see either oil or coolant leaks just before they let loose!
Nope those would be the old style and prone to failure, might be worlds ahead and just change them before failure!It has the tabs, sooooo, I'm assuming it's a new style head gasket?
And the shop trike!Cam, head gaskets from blown motor, and of course, the disgruntled shop help. . .![]()
