M-37Bruce
- 60
- 28
- Midlothian, VA
That's not a Saginaw box is it?
Not sure it came off of donor truck which is a 79 dodge w200That's not a Saginaw box is it?
I seen a video of a guy with a power steering kit the box looks like mine but it looks like he mounted it on its side wondering if I can turn mine 1/4 turn on it’s side and get better wheel clearance since mine will rub on full right lock with tires over 33” tallNot sure it came off of donor truck which is a 79 dodge w200
I have no idea the valve stems are missing and the tires feel hard as concrete tires weigh close to 400 pounds eachCould your Hummer tires and wheels have the run flat donuts in them ?
Thanks I’m hoping to be driving it this spring gonna leave the exterior just the way it isThat’s going to be a nice ride
Thanks ! As far I steering wheel I’ll have to research it was thinking maybe a two part epoxy putty but not sure ! Have any ideasYour floor is looking good, your wheel looks just like mine used to, any plans for repairing it?
Ok thanks I’ll give it a tryJB Weld will work fine . It’s tough to work when it’s set up , but power tools are your friend
PC- 7 works well for repairing steering wheels.Ok thanks I’ll give it a try
Ok thanksPC- 7 works well for repairing steering wheels.
Frank
