Air Intake
73X
9
Farmington Hills, MI
That is actually a good looking antenna mount, it doesnt stand out and look obviously civy like most cb antennas on MV's
Thank you for your kind words. I tried to make something easy and that would blend in a bit with the truck. I know that a civy antenna looks out of place but the goal was to try and do something cheap and easy that would look decent.
I just cannot justify what a military antenna and mount cost when this was so darn easy.
derby
10
S.E. MI.
I think the intake looks good! I also don't think there would be any ill effects to the cap being up there. My five ton is level off the top of the filter from factory. also since the intake is 3 1/2" and the pipe is 4" there should be no added resistance. I will think of this the next time I have to clear the snow off the fender by the intake.:)
Pearadeuce
Climbing Hill, Iowa
The military have a under water kit I think but didn't want to add the add air lines and change the trans plug to keep water out. check out video on you tube
[media]http://www.youtube.com/watch?v=ICKLGYs8CE8[/media] or search m35a2 deuce under water don't know if link will work never done it before
73X
9
Somehow the post maintenance just isn't worth the ride. Not to mention in today's way of thinking I surely do not need the tickets and bad press this would provide.
