Aluminum wheels
olly hondro
593
tucson AZ
Having zero threads sticking out weakens the fastened joint. Without protruding material to provide a backstop for the last couple threads of engagement, forces put against those last threads just roll them over off the end of the bolt.
I will have to think about that. Ensuring the fastener is engaged, backstopping, and the "feel good" of visual confirmation. There is some good physics in there somewhere.
Alisabarn
Oklahoma
Happy to help. I will have 4 kits worth of stock in next week, let me know if anyone is interested in purchasing. (I can also get any other Hutchinson products you may need, just provide part numbers and qty needed).
Hey Brennan, do you happen to have any more of the Kits? All I need is one Left and one Right CTIS Lug but getting a kit for 4 tires is fine and having spares is always a good idea.
First post BTW so I can't PM yet.
GCecchetto
317
Woodside CA
Thanks...They do have two recesses on the back.
Sounds like you’re going to need those o-rings too then. I’ll look in the rebuild kits I have to see if they are included. Most likely are and valve rebuild kits are good to have, so you might want to pick up some. Typically cheap and easy to find.
GCecchetto
317
Woodside CA
Okay, so yes, the valve body for the aluminum wheels uses two o-rings between the back of the valve body and the rim, photo below. The aluminum rim valves use the same internals as the steel wheel valve and the rebuild kits I have for them do not include the o-rings for the back. These kits are technically for the steel wheel valve, so, I'm glad I looked into this so I can source the o-rings.
Picked up another unused rim and tire locally yesterday for $500. I already have a full set of 5, but couldn't pass this up. tire is a 2016 date code with sticker on it still and the seller said it was stored inside. Still won't run this tire on the front though since I don't really know its history. Valve Body.jpegWheel.jpeg
Alisabarn
Oklahoma
Picked up another unused rim and tire locally yesterday for $500. I already have a full set of 5, but couldn't pass this up. tire is a 2016 date code with sticker on it still and the seller said it was stored inside. Still won't run this tire on the front though since I don't really know its history. View attachment 947106View attachment 947107
Thanks for checking. I'm thinking finding appropriate o-rings won't be difficult, but the two CTIS lugs are gonna be tricky.
GCecchetto
317
Woodside CA
Yes, the CTIS lug nut are stupid expensive and you have to be patient to get them. You used to be able to buy them directly from Hutcheson, but they no longer deal with the public directly. They will refer you to one of their distributors, which are all military suppliers and thus are incredibly slow and inefficient to deal with. It took months for me to get the 4 I needed and with shipping cost over $100 per nut, if I remember correctly. There was a vendor here on the forum that said he was going to stock them, so you might try him first. Good luck.
Frank_Online
The Netherlands
If someone in Europe needs parts for these rims I finally have a connection with Hutchinson UK. Only the prices have gone up to unreal levels but that's still beter then not possible to buy. They did send me a lot of information for parts and powder coating these rims. I will share them here so people can benefit from the original guidelines from Hutchinson.
- 50065 - O-Ring CTI Hub Port
- 50065 - O-Ring CTI Tyre Port
- 60220 - Kit, CTI Lug Nut, Left Hand Thread
- 60221 - Kit, CTI Lug Nut, Right Hand Thread
Hope this helps other people on the same journey.
