- 7,564
- 10,602
- 113
- Papalote, TX
The diffs are completely and totally incompatible, you will not be able to use anything from the 2006 but for the engine,trans and transfer case.Thank you for the information. I have a 2006 duramax truck complete. I was planning on changing motor, trans and dif. I'm not sure what the gears are in the 06 but I'm just in the planning stages so things can change quickly. I restore cars for a living and am not scared but I also don't want to waste money or time. The M1151 is my wife's Christmas present
Sent from my SM-G990U using Tapatalk
Even with a body lift it is like stuffing 10lb of crap in a 5lb bag and this is a TOTALLY different animal than anything else you have ever worked on and it seems you have not done your homework.
I am not trying to discourage you but this is not an easy project, in fact it is not even a difficult project, it is much more than that.
You're right I haven't done enough research yet but I'm working on it. Before I start tackling any of that I need to source the correct gearbox for the steering. Honestly before this Christmas I'm just trying to get it painted tan like she wants it, and getting it to look a little bit more presentable. I'll take any help I can get with the mechanical side of it. To be honest I am not good at the mechanical side. I specialize in painting, body work and metal fabrication.
the plate # on hers is 258030. I'm going for one above 300000. Thank you for your advice.
