JasonS
- 202
- 63
- Eastern SD
Most truck/ industrial engines use an SAE bolt pattern for the starter. Its when you get down to the car/ pickups where everyone has to be different.
So what should I do, cut one off?The bendix should have 11 teeth.
Maybe I need to count again?gringeltaube said:So what should I do, cut one off?The bendix should have 11 teeth.(all my starters have 12 teeth...) G.
Interesting info Bjorn! So there are different models indeed!?cranetruck said:MS53011-1 has 11 teeth
MS53011-2 has 12 teeth
MS53011-4 has 13 teeth
