wsucougarx
- 63
- 48
- Washington State
Lookin' good guys! Really good.
Jeff is that the current desert sand/tan?Local Home Depot said they could mix paint by the FS#. I'm gonna try FS#33446 tonight.
Jeff
It went over a combination of grey primer and old paint. Everything was prepped with a DA down to 120 grit.1.What did you apply the Behr over? It does best over primed or scuffed surfaces? Does exceptionally well over old oxadized enamel too.
Several coats and they were applied with a hvlp gun. I'm planning on putting one final coat on once everything is back together to make sure there's an even appearance and to catch any spots that might be too thin.2. How thick did you apply it? My gun put it on the thickness of a business card, maybe a little less. Thick enough to cover up deep 80 grit sanding scratches. Uses a lot more paint, but man does it hold up well.
So far we've used 2 gallons and part of a quart on a 3/4 ton truck so less surface than a deuce.The Behr does NOT fare so well when put on THIN. My truck took around 2 coats and went on textured, not smooth. It is flat as well, not semi gloss or anything of the sort.
I know it has been asked several times, but no one has answered, what is the current desert tan/sand codes/mix?
1. I would thin unless you are using an airless sprayer. Thin what you need to get the sprayer to spray an acceptable fan pattern. ie:not splattering and not running.1. Has anyone needed to thin their paint with water? (Behr states no more than 8 oz water per gallon)
2. How much paint is being used for an M1009?
3. Which sprayer has everyone been using?
4. What grit sandpaper are you guys using for prep? (wet or dry?)
My method is not for everyone but it is an option depending on what the end result you want is and the purpose of the truck etc.1. Has anyone needed to thin their paint with water? (Behr states no more than 8 oz water per gallon)
Just finished my deuce using behr. Here are some before and after pictures.
