Behr Paint Jobs- Show me your MV's
JoshHefnerX
Glendale, AZ
I painted my truck a couple weeks ago with the following:
1 gal Behr marquee paint
1 bottle flotrol
12 oz of water
Paint color is 383 Green (FSS 34094)
I was spraying with the harbor freight HVLP turbine paint system and used about half the paint. Next time I will probably add more water. It looked very rough when I was spraying it but smoothed out to a pretty good finish.
How big of a bottle of flotrol did you use with the paint whne you sprayed?
bikeman
502
Ft. Bragg, NC
Well, we are going to be attempting soon on the M880. Either tomorrow or next week/weekend. Trying to get her ready for the Veteran's Day Parade 7 NOV.
shepherm
Mustang, Oklahoma
That may be the size of the bottle, but there are specified amounts printed on it. One bottle will do many gallons. It's not 32oz to the gallon.
You are correct there are instructions, and I followed them, up to 32 oz per gallon of paint with airless sprayers. My HVLP gun needs thinner paint than my airless sprayers, so I worked up to the max ratio. With the HVLP gun and high air temps I was spraying in this seemed to work good, but if you are painting with a brush or in cooler temps you may need a lot less.
1bonehead
Maryland
Were you aware of the OSHA regs, robson1015?
They might not apply to you as long as you don't contract for outside work. But there is a reason for the regs, and you'll want to consider the reasoning (especially driving in a cab in the "firing zone" of that regulator). You don't want to get hurt. Easy enough to mount the two tanks vertically fore-and-aft it looks like.
They actually make a regulator "cage" that allows for legal transport with regulators on. Not to expensive and helps save the regulators from being beaten up.
That will allow for transportation of the bottles with those on but I still would stand them up. I have seen them break free when the valve stem broke off. They will do a lot of damage.
JoshHefnerX
Glendale, AZ
Well, I can say that here in phx @ 90 deg you need more than 4:1 flotrol. I mixed up at that ratio w/ a couple of oz's of water mixed in and the hf hvlp did kinda splatter. So the texture is pretty rough. However, I'm happy with it, covers up my crappy bodywork. lol
I will also say I had another learning experience. I decided to try rolling the roof after work one night. It was cooler (for phx) by the time I finished- maybe 70-75 and a bit humid as we'd had a couple of days of rain. The dew that popped up overnight managed to wash the paint off the top and down the sides all over the concrete.. I was kinda flabbergasted.
Kloakndagr
On The Road/California
I painted mine two years ago, Home Depot paint, Home Depot airless sprayer, I'm going to touch up some areas, for the most part the paint held up well. In fact I using the same paint to paint the 28 foot enclosed trailer it going to pull.
Kloakndagr
bikeman
502
Ft. Bragg, NC
Hey guys,
My buddy, the painter, is concerned about the durability of the Behr paint. It is showing some very easy scratch marks. I'm figuring it'll take a few days (longer when it's cold out) to fully dry and such... how off/on am I on this?
Coffey1
497
Gray Court SC
Bike mine is holding up well just got back from rally.
The only scratches are on the flat camo spots.
And the mud comes off easy on the behr.
By the way I used semi gloss because the flat does scratch and holds mud.
tobyS
833
IN
Hey guys,
Used Behr Ultra Premium on my 817 dump truck with floetrol. It takes from a week to a month to fully cure. Reminds me of the cure rate for concrete. After 111 loads, it needed a touch-up. Red oxide primer on rust is a must.
Doc2012
Jacksonville, NC
So, I want to get this straight.
All I have to do is go to HD, tell them to look up competors paint, have them use the federal standard paint code, and mix it, correct?
SO, if I wanted to go with a Medium Gunship Grey, I would tell them to use the Federal Standard Code 36118, correct?
Got that code from federalstandardcolor.com, for those that willing to help out.
