- 3,151
- 4,738
- 113
- Olympia/WA
The BEOD is supposed to be mounted to the M1097A2, which is a standard A2 heavy variant with the 4 speed transmission. I have never heard of any military HMMWV having a 6 speed transmission.Just electrical shorts and the fan relay going bad constantly. You can bypass the fan relay clutch by unplugging it, and many maintainers suggest it due to the loads carried.
As far as coolant problems, we constant have cracked radiators or the coolant system dumping everything.
I’m not near any of the trucks now but I can tell you that they have a 6 speed transmission not the standard 3 speed found in the 4 seaters.
Photo wise, what are you looking for? It’s essentially a sectioned box in the back for organization and a 2 seater up front.
So when you say electrical issues, you are talking about the HMMWV itself having issues, not the BEOD?
As for the photos, a few posts back I took pictures of a couple aluminum pieces that came with my BEOD, and never did figure out exactly how they were supposed to mount. Other than that, just some inside pictures showing all the different areas so I can see if there is anything I have or don't have that is supposed to or not supposed to be there.
Thanks.
