steelandcanvas
- 87
- 48
- Southwestern Idaho
Stuart, I don't think you'd ever be sorry you bought one.I need to get one of these little gems (MEP-003A) myself. That and a Base-X 303 tent.
Jonathan,Stuart, I don't think you'd ever be sorry you bought one.
My closest GL is Ft Carson, that is where I purchased my 003A. If we find one there, I have a couple of Club Members in Colorado Springs that might inspect it for you, if fact one Guy was a genset mechanic. What do you think?Jonathan,
I'll just have to keep my eye out around the country and just pay some shipping.![]()
I know this is an ancient thread but I just have to add my 2 cents worth. I lived off grid for 10 years. I used batteries and generators and kerosene lanterns. I lived like this not because I wanted too but because power would cost over $20,000.00 to bring in. I bought a 500 gallon propane tank and 4 one hundred gallon tanks. The hundreds powered my house utilities ie: furnace, dryer, stove. The 500 gallon fueled my generator. I had a 10KW generator with the Vanguard 18HP engine. I had this with a remote starter, so I could start and stop it from the comfort of the house. Now here inlays the problems I had. You must run a generator at least 8 hours a day to keep your batteries up and your freezers working. Actually it got run on average 12 hours a day. The generators would only last about 1 year. I had one last 2 years. This was with running synthetic oil and changing it out twice a month. The problem was not the rings or cylinders, (which would look NEW after teardown) but the valves. Propane does not lubricate the valves like gasoline or diesel does. What would usually happen is the generator would be running fine when suddenly flames would start shooting out the exhaust ! I would tear down the engine and find the exhaust valve sucked up into the head, completely destroyed ! This happened everytime. So for someone who wants to have a dependable generator I would only go with diesel. I now own one MEP003a, two MEP002a's , one 30D36R 3KW, and two MEP-501a 28volt units. All work great. Don't get me wrong, propane generators have there place, but not as your main back-up for your house in my opinion.I also have a 003A
But I always felt a tri-fuel genset would be nice, it would give the the option of burning gasoline,LP or NG or even one that just runs on LP., You would never have to worry about old gas in the tank or carb and storing/buying LP is not a problem
I also was the main mechanic at a large fleet that used propane vehicles. I personally had a 3/4 ton pickup converted to propane.(wish I hadn't sold it ) So I know that propane works great, but you need to know it's pitfalls too. The Ford V6 your using has ample oil to the valves, and I'm sure the valve seals are leaking just a little bit as almost all do unless you go to the hi-po specialty seals. But even so after time you will see wear to the valves due to the lack of lubrication. On a small engine like the gensets use this problem is greatly increased due to the lack of oil (smaller system) and smaller valves themselves. One of the problems modern diesels are facing is the low sulphur fuels used to decrease emissions. This also has less lubricating qualities and at first use, injection pumps where failing across the nation ! Now newer seals and other internal parts are being used to prevent this. Go and ask any repair shop that deals with propane gensets and they will tell you the same thing. As far as my area goes, I live in the woods, 50 miles from the water, no sand, air is fine. The problem is the fuel. Tear down one of your gensets and look closely at the valves and seats, you will see what I mean.I don't quite understand why this would happen. Is it definitely the fuel? Diesel is just air passing the intake valve and (if its running well) burning gases passing the exhaust valve, not much different than propane. Gasoline will only lube the intake if the fuel provides any lube.
I also have had several propane/ng gensets run for years as standby's that are still running great today (granted, not as long as yours would run). One I have now is an adapted Ford V6 that's been faithful for 6 years at least.
Are you sure that's the result of propane and not something else? Sandy atmosphere, thin air, close to seawater, etc?
