Bringing back to life a 2009 HMMWV M1165A1 from GovPlanet - total newbie, please help...
Coug
4,736
Olympia/WA
the check valves aren't really needed, so once they are removed just forget about them.
T9000
370
California
And what do you recommend as a good parts cleaner? I didn't rinse/ clean the fuel filter casing with anything, just drained the diesel from inside, but I feel that maybe I should clean it/ rinse it with something, but I don't want to introduce any contaminants, what is the best?
Gamble
375
Los Angeles, CA
Got it! I appreciate it! If I understand this correctly, you are saying to remove them to see if it fixes the problem, but then eventually replace them with new ones?
BTW, your truck looks very good, what tires do you have on, 40/13.5?
40x15.5r20
T9000
370
California
40x15.5r20
Looks good! I just eyeballed the tires, the picture is very dark and can't really see the wheels :)
There are several check valved and just to make sure I pull the right ones, I think you are talking about the two marked in the attached picture?
T9000
370
California
I am about to install the fuel filter back, any recommendations on a good parts cleaner? (I am thinking of not introducing contamination) Or should I leave it alone, just draining the diesel from inside?
mgFray
992
Southern Minnesota
I've used Kerosene as a parts cleaner before on diesel engine componets in the past. It's generally compatible with diesel. (I don't know if any agrees this is a good or bad idea on the HMMWV.)
Coug
4,736
Olympia/WA
Kerosene and diesel are pretty close; Kero is just much more highly refined.
There shouldn't be any issues if mixed with regular diesel, but running it straight might not provide enough for the injection pump leading to premature failure.
JP-8 is a 100% kerosene fuel with additives, and these trucks were run on that for their entire military service life (or possibly not, but I know in Korea in my aviation unit it's what we always used)
T9000
370
California
Ok, I got the Kerosene down.
And how about a spray/ aerosol type that evaporates?
Are you using anything like that?
Coug
4,736
Olympia/WA
For parts of the fuel system you can blow out afterwards with compressed air, I buy denatured alcohol by the gallon from the hardware store.
If it isn't something you can blow/dry out afterwards, then diesel or kero will be fine.
Gamble
375
Los Angeles, CA
Not easy to tell from this drawing but I believe so. The check valves are on the passenger side in the rear of the truck on the fuel lines attached to the body of the truck above the frame rails. See encircled area.
Action
1,564
East Tennessee
They are at the front of the tank. Easily accessed from under the truck. You will see 4 metal lines on side of tank. 2 are just looped together. Leave those alone. The other 2 tubes lead to the check valves. About 12” in front of the tank. Closer to below the front seat.
Gamble
375
Los Angeles, CA
Maybe they're easily accessed with a lift or a long needle nosed pliers but otherwise they were a pain in the hind parts to get out. 😉
T9000
370
California
Use a razor blade to cut the rubber hose on the hard lines. And use diesel rated hose to put back in. Normal fuel hose from autozone is not rated for diesel.
You guys are awesome! I appreciate the help very much, and Action you read my mind about the fuel line, and when I am not sure about something I go full OCD so I researched the Autozone fuel line...it is NBR ( Nitrile Butadiene Rubber) rated SAE J30R7 which it shows recommended for diesel up to 50PSI, but of course nobody at the store had any clue. The Autozone web site lists the hose being Continental, but in store they had ArmorMark, also rated SAE J30R7 Made in Thailand, but I am looking to buy the Continental,which is Made in USA. It's only $1.99/ ft, here are the specs:
https://www.continental-engineparts.../Fuel-Line-PCV-Emission-Control-Hose-SAE-30R7
The J30R9 is rated at 100PSI and it works with B5, B10, B20 Biodiesels also , where J30R7 is not recommended for Biodiesel, this one is about $7-$10 per foot:
Gamble
375
Los Angeles, CA
Here's a pic of what you're looking for from under the truck.
T9000
370
California
I see what you mean, they are buried deep in there, I will find them, now I know where to look. I promised the kids to take a break from the truck to spend time with them and will be back working on it next weekend. The new tires are arriving next week too, I wanted to go with 40s and change to Black Rhino Armory wheels, but everything is back ordered to January maybe longer. I looked also at Super Swampers SSR and IROKS 39.5 and those were also pushed past Jan 22nd and even March, I went with a set of standard 37s MT OZ for now.
Happy Thanksgiving everyone if we don’t talk before then :)
