Cargo Floor Section
revhrd
Las Vegas, NV
Does anyone happen to have a section of the cargo floor that is able to part with it? On my M998 it came with the "upgraded" access panel for the fuel pump. But it was a hack job and I'd like to make it better. I know it's a long shot but I figured it's worth a try before looking elsewhere.
Retiredwarhorses
3,893
Brentwood, Calif
It’s not for the fuel pump, it’s for the sending unit for the fuel gauge.
TOBASH
3,057
Brooklyn, NY
You can easily make that out of fiberglass or sheet aluminum flashing.
revhrd
Las Vegas, NV
Correct, at the time of posting this I had not looked at the parts manual. After a bit of research, I can see that the pump is inline. I had read about the filter sock here and jumped the gun into thinking that it was a typical in the fuel tank pump. Is there ever a reason to unbolt the rectangle cover? The current cutout, while not clean, does give me the ability to uninstall the sending unit.
