- 3,177
- 4,796
- 113
- Olympia/WA
I have heard the concept mentioned before, but not sure if anyone has actually done it.Has anyone thought about rewiring the batteries through the slave port so that it acts as a disconnect? Install a plug (with the pins jumpered) and the battery is connected. Remove the plug and the batts are disconnected. Security and safety all in one. Yes, this makes the slave port non-standard but if you're never gonna use it..... Would be exciting to see the next owner use it as a slave port......![]()
You could do the same thing, and probably easier/cheaper by adding an Anderson plug somewhere in the system to do the same thing.
