Cranked the injection pump up, engine ran away on startup...
ajsmith184
Howell, Mi
Just finished my 6.5 turbo add on...I did the whole "touch the wires to the injection pump and listen for clicks" twice and it clicked both times....Started it up and it ran straight to redline :cry:aua
To say it scared the **** out of me is an understatement...I immediately grabbed a rag and stuffed it into the turbo to drown it out....Whole thing lasted maybe 10 seconds...
Im done for the night...Disassemble the injection pump and check tomorrow..But with it clicking before this time, I dont even know what to look for?
I hope I didnt hurt the engine aua
Was a tad loud with open manifolds too..Will go and apologize to the neighbors in the AM for any possible Thanksgiving day racked at 730pm lol
1,168
Get any video?
ajsmith184
Howell, Mi
I dont know...Yes Im pretty sure that is the shut off valve clicking. I checked, its not now..maybe (hope) the linkage bound up. Will disassemble and do over. Ive heard of other diesels sucking oil through the turbo, dunno about these though? Why i asked here :)
4,622
So just how much did you "turn it up"? You should have only needed 1/16-1/8 a turn without gauges. 1/4 to 3/8 if you have gauges and drive by them.
ajsmith184
Howell, Mi
1/4 turn for a turbo, have guages.
I just took the top off again, reinstalled..Touched the pink wire..No click. I dont know where to go with this?
1,168
Get video for the next startup!
1,168
I'm pretty sure you're gonna get banned, if you didn't take video!
ajsmith184
Howell, Mi
So no damage? I hope?
Well, now Im not so sure.
Initially in the mindset of ready to smother it again and it starting so well, I shut it off. Played around and got the boost guage in etc
Just started it again....And noticed the coolant/engine oil light is on. Immediately shut it down..I went and checked the ground by the coolant sensor, seemed good..Started it again and only the engine oil light on now.
Im hoping when running the oil line I bumped/messed up a ground..I am getting into the TMs right now...I sure hope nothing internal is going on.
Any other car Ive seen the dummy light coming on is almost too late...I cant hear any knocking, noise, or anything else that would indicate low oil pressure..Fingers crossed its a sending unit or wiring issue.
