CUCV 01 finaly made it to hamburg germany
ssdvc
639
CT
thx!
the underdash starter relay mod?
nope... a must have?
Nice looking truck, nice work.
Yes, the DOGHEAD mod is a must do. Save yourself from a meltdown.
What a the round containers left and right sides of the rear cargo section of the truck? They look like storage containers (nice idea).
Nico
15
Germany, Hamburg
I am going to use the search Funktion about the Mod. THX 4 the advise.
the Containers are just Loudspeakers.
update...realy ordered
Nico
15
Germany, Hamburg
pretty complete history of the M1009.
on duty in:
Arkansas Camp Robinson, Installation Support Unit.
Stancils on the Hood and Bumper say´s US ARMY CU387R
tbearatkin
25
SouthWestTennessee
this m1009 was stationed in arkansas, little rock afb.
than showed up in texas at a electrition company called "grant electric"
used as a maintanance car. you can see a lot of cucv`s in the yard...(ss member?)
i discovered my cucv there on the "steet view" pix.
there she is next to the duce...
I was stationed with the owner of Grant electric many years ago(24) in Bermuda. He was a Seabee Electrician great guy. I am trying to get him to part with a M1008.
Nico
15
Germany, Hamburg
after 2+ years driving this m1009,
i am pretty glad that i have no issues since 8 month.
i had almost every defect a m1009 could get!
ill try to create a list of all i did to make this O´9 a nice ride.
Rough running engine and ticking noise in cold start, only 90km/h, poor heating power...
-New Diesel Fuel Filter
-New Air Filter
-Repaced cracked cooland reservoir
-New AC Delco 60G glowplugs
-New Glowplug controller card
-NOS injectors (tested, 5 of 8 where bad an needed do be overhauled)
-Replaced the Fuel gauge with a used one.
-New Heater Switch
Cooler leaking, Transmission leaking, Fuel lines Leaking, proportioning valve leaking. air in the diesel system.
-New front rubber brakelines
-New proportining valve
-New rubber fuel line
-New diesel pump (generic product not working, a new ac delco fits to the fuel pump push rodgeneral)
-New Vacuum pump
Noise from the Engine Block
-Lost a bolt at a front shock and a bolt at the steering pump bracked
Rear axle defect, bad noise
-New bearings
U-joint defect
-New bigger Driveshaft and u-joints from high angle driveline
Bad Starter noise, scratiching on the flywheel
-New Starter
Bad Glowplug Relay, 5x 60G glowpugs defect
-Again 8xNew AC Delco 60G glowplugs
Hydrobooster and New Proportional valve leaking
-New Hydrobooster and Proportional valve again, change to dot 3
Bad Starter Noise again, th 400 defect, No accerleration sometimes
-New Flywhell
-New Overhauled Starter again
-TH 400 Rebuild
-New Fuel Injection Pump, 180HP Tuning Pump <--The ticking noise in coldstart is gone. Low pressure problem on the old one
-New Modulator
Whiper motor defect
-Replaced with a used one
Leaking Cooler
-Replaced with a new one
poor Heating power
-Heater Radiator Repaced with the recommended on this page
still poor heating power, maybe a valve not closing correctly.
fuel gauge defect again. at full, pointer shows 4'o clock
Starter permanent runing problem
-New Starter again
-Doghead Relay Mod
Gen 2 Defect
-Gen 2 Rebuild
-Gen 1 Rebuild
-New T-Belts
Gearshift Pointer out of order
-New Grearshift Pointer
ODFever
Madness Takes Its Toll...
73
Orlando, FL
I like your truck and your display! :) What are you using to support the canvas with the cross on it?
Nico
15
Germany, Hamburg
Some pictures of the desaster:
Leaking Fuel
Broken Bearing Rear Axle
Glow Plug Relay Stuck
Injectors Burned out
G60 Burned throu
Bad Flywheel Tooth...
Doghead Mod
Gen 2 out of order
After Gen Rebuild, New 12v Dash Lamp, Sanding the copper socket, New Gen 2 Relay and cleaning all gound terminals...the GEN2 Lamp still not working! drives me crazy
Nico
15
Germany, Hamburg
Thx ODFever, this is a bundeswehr redcross canvas. i used a pair of "poles" from the bundeswehr camouflage net to build a shelter.
