- 2,479
- 27
- 38
- Houston Texas
Do you know what end you have? Could the broke piece still be in the bore aginist the camshaft? If so, then slowly rotate the crankshaft by hand with a socket on the harmonic balancer bolt. Then see if the cam lobe will push it out of the bore. If not, then if I was in your shoes I would pull the oil pan. I say that because I would hate to worry about it coming up when you hit a speed bump or off road. Then getting hit/caught by the crankshaft and busting something. It's too big to get caught in the oil pump pickup screen. But small enough to get itself between a crank weight or a connecting rod and the block. You will need to unbolt the motor mount and lift the engine for the oil pan to clear the cross member. And don't forget to rotate the vacume pump away from the firewall. Before you lift the engine. Or it will hit and damage it. (don't ask how I know that).
