CUCV-II Northern Europe Reconditioning
marchplumber
3,454
Peoria, Illinois
Was it anitfreeze or just moisture? Antifreeze, ya might have a heater core going out. Moisture only, does yours have "vents" under the dash on both sides? If so, check the seals on the the side vents. Just a thought
Nico
15
Germany, Hamburg
Some important updates ;-)
A Sticker for the
Ex Iowa Air Natoinal Guard PU
Diesel lift/supply Pump replaced
as routine maintenance.
Glowplugs replaced
CDR-Valve replaced,
...and the most senseless gedget ever:
marchplumber
3,454
Peoria, Illinois
Nico
15
Germany, Hamburg
Time to clean up.
i hope that will solve the "water at the passenger floor" problem.
some paint for the wiperarms
done, cleaning behind the blower motor is on my list.
the most important part is missing in this picture...
reinstalled the underhood lamp :clinto:
Nico
15
Germany, Hamburg
it`s desert dry underneath the floor mat since i cleaned the vent system.
it seems that the water going the wrong way if dirt prevents the running out.
