FireFighterHill
Banned
- 1,540
- 62
- 0
- Riyadh, Saudi Arabia
Anyone ever done it? I think the multi fuels could gain alot from this.
don't forget the money that'll have to be spent on new gaskets.add 1si of boost to get that kind of cfm improvment. it's not going to help much. I have tried this on other motors. if it was a NA motor then I'd say yes it could help a lot. but with a boosted engine, porting will not help near as much. there are many other ways to get more power. you should spend about 120 hours to do this properly on a multi and you could net nearly nothing.
WM, I'd be afraid I'd end up with a little too much bang if I did that.I'm no diesel doctor but I would think that turning up the fuel to 2800 and adding propane injection would give more bang for the buck to increase HP.
There was a thread where somebody added one to a 5-ton multifuel. The grill had to be redesigned though.An air to air or water to air inner cooler might help but finding some place to mount so as to be protected from damage would be a challenge. And how about modernizing the turbo something with say ceramic bearings.
The intake is already an air to water cooler. That's what that big 'ol log above the exhaust manifold is.There was a thread where somebody added one to a 5-ton multifuel. The grill had to be redesigned though.
I'm wondering if you could use a A3 front grill and fit a innercooler in there?
Will, there is some debate as to whether the water in the manifold heats or cools the air. Some say it's to warm the air in cold climates.The intake is already an air to water cooler. That's what that big 'ol log above the exhaust manifold is.
