DIVE DIVE
- 778
- 93
- Chesapeake, VA
1) The pink wire is .8 PNK-30 (SXL) and goes to the fuel tank sending unit which is where your fuel gage signal comes from. See figure F-4 on the right near the middle. The shorter tan plug wire is .5 TAN-31 (SXL) for oil pressure. See figure F-3 bottom left.Good afternoon everyone,
Hope y'all are having a good Memorial Day weekend. Definitely going to take some time today to sit and reflect on our veterans while I wrench on the old '86.
1) Yesterday I started labeling the new engine wiring harness, I got a majority of it done. I could not figure out what these 2 go to (431 .jpg attachment). The pink long coiled wire looks like it's the fuel shutoff? I traced it down the frame to the fuel tank. The shorter tan plug wire... that I think goes to the back of the block. My gut is telling me oil pressure? (I have a GMC with a sending unit in a similar location).
2) the 447 and 504 .jpg - I see where this pink/red connector plugs in. What is that called? I couldn't find it in the diagram but I could find it in the truck. It's on the front of the motor toward the top where the oil filler neck is.
3) 841 .jpg - what is that green connecter? Driver side, front of the motor, it's not a glowplug. I think it might be coolant temperature?
4) 905 .jpg Look at this mess going to the glow plug relay. Good grief. Under the dash is about 10x worse, I'm glad I picked up a dash harness too. He redneck engineered a glow plug button into the truck. I will be looking under the dash and seeing if that's where those wires go to. I could find on the glow plug wiring diagram the pink/black, blue, and orange wires are original. There's a stripped black wire and stripped... I don't even know wire. I haven't found where they go yet but I have found them go to the glow plug relay then go into the firewall. They might be black and yellow going to a temperature sensor somewhere? I'll be looking more into that situation today. The glow plugs work though, no clue how.
Have a good weekend y'all.
2) That wire is the Fuel Shutoff 3 PNK-3 (SXL) See figure F-3 bottom left.
3) Coolant Temp .5 DK GRN-35 (SXL) See figure F-3 top left
4) Good luck with this one
