Declassified rarities from USSR
marchplumber
3,485
Peoria, Illinois
Thanks for all the effort you have put into sharing here on SS! Great thread, very informative and just plain fun to read! AMAZING machines, amazing people. Congratulations on your new daughter! They are a hand full!
God bless,
Tony:grin:
USSR
316
USSR
Gas-dynamic minesweeper "Progrev -T"
Defeat the enemy can be a thousand different ways. This - 1001y. The enemy can simply blow away. Forever. And at the same time to burn. Completely. At any depth.
Gas-dynamic minesweeper "Warm-T" and is intended for detection and destroy mines laid on roads covered with asphalt. Built on the chassis of the T-54 mounted with a turbojet engine VC-1.
With help gas jet tank was burned land mines. Mines that remained were raised to the surface using of "beak" visible from above. However, the dust at work, engorgement and low engine speed buried the idea.
Specifications of the system "Progrev-T"
- Combat weight - 37 tons;
- Bandwidth trawling - 10-12 m;
- Trawling speed - 1 ... 3 km / h;
- Reliability trawling - 99%;
- Continuous operation time - 2.5 hours;
- Minesweeping operations in depth - up to 20 cm (when working with the opener mechanism - up to 50 cm)
USSR
316
USSR
TPP-3 - Transportable nuclear power carried on the four self-propelled tracked chassis, established on the basis of the T-10. TPP-3 was developed in the Physics and Power Engineering in Obninsk. The chassis has been developed in OKB Kirov Plant by lengthening the chassis of the T-10 (and, consequently, increasing the number of rollers to 10) and increasing the width of the track to keep ground pressure to the extent necessary.
Two-circuit thermal capacity of the heterogeneous water-moderated reactor that is installed on the two self-propelled - 8,8 MW (electricity, with generators - 1,5 MW). On the other two mobile units located turbine, generator and other equipment.
TPP-3 entered into trial operation in 1961. Subsequently, the program was phased out.
jamesfrom180
73
Gainesville/Florida
Very cool! I have been fascinated by this application. These are the first pictures I have seen of the installed operation. I see now the intended use of the multiple building. Congratulations on the new daughter.
USSR
316
USSR
Object 327 - Soviet 152-mm self-propelled gun with a high degree of automation. CDB is designed plant Uraltransmash "under the leadership of NS Tupitsyna. The unofficial name - "Puck".
In this machine solved the problem of excess gas in the fighting compartment.The machine was created on crazy scheme, which resembles a plate ( and got the unofficial nickname of "puck"). The crew was housed in an isolated fighting compartment.
Series not was made.
big block 88
Topeka/Kansas
in our country has always been .. so your Abrams - a useless pile of iron on our roads)) (but only do not be offended) ...
Watching the Abrams navigate the city of baghdad and i can tell you it was to large for alot of those streets. But nothing a 120 can't make disapeer.
Carry on this is very interesting stuff.
USSR
316
USSR
Initially, in this the topic I planned to talk about trucks, but now has expanded the list)))
USSR
316
USSR
These are just incredible wheeled monsters makes the Kraz , 10tons and Maz 537 to looks like toys next to them...
Jim
On photo - MAZ.
MZKT-79221 - a special heavy-duty wheeled chassis of the Minsk Wheel Tractor Plant. This chassis is used in the mobile launcher for the complex PT-2PM2 Topol-M". Was developed in 1996-1997., serial production started in 2000 for mounting civilian equipment manufactured modification MZKT-79221-100.
