Deuce batteries or starter
1,193
yes, and yes.
779
20
Springfield AR
Ok I had a bolt too long holding the flywheel from bellhousing my fault wow works great now lol.Thank you doghead so much for all your help and others as well now on to finding that sleeve and pin for transmission.
FloridaAKM
395
Gainesville, Florida
This is why Doghead wanted you to turn the engine over by hand, to see if there was a mechanical interference somewhere in the power train. Glad to hear that you got it all sorted out. We live & learn, this forum & its members are a great asset to the hobby.
779
20
Springfield AR
Ok she's up and running need to adjust new brakes and bleed them spongy.I also wanted to note 5th was kind of stiff going in.Its probably because of sleeve pin and needing broke in I think.
rustystud
3,394
Woodinville, Washington
You did use the correct flywheel bolts right ? You cannot just use any old bolt here. First off they need to be grade '8' and second they need to have a shoulder to engage the flywheel so it does not loosen. If you used the correct bolts then it would not have had any contact with the housing.
1,193
Please try to explain what bolt you are talking about, I don't understand your post.
779
20
Springfield AR
Bell housing bolts not fly wheel bolts. Those bolts are brand new from were that LDS was rebuilt.The bellhousing I used a longer bolt to help line up on bottom.I am sorry for the confusion just been running ragged working on my truck.
