Deuce muffler option
RAYZER
59
sanford/florida
You notice the difference more at lower speeds, hearing protection is still required at higher speeds. Imo.
Tow4
671
Orlando, FL
I put a Walker Big Truck muffler on my Deuce W/D turbo. It made it quiet enough to drive around town without ear plugs. Over about 45 MPH the rest of the drive-train is singing and howling so you still need hearing protection on the highway.
FMJ
37
Las Cruces, NM
doesn't sound like much, but 4 db's is significant.
3db down = half as much power when dealing with RF, not sure if this applies to sound, but if it does. . .
I put the same muffler (moroso) on my Deuce much nicer.
welldigger
Benton LA
If I had to guess the aero muffler reduced sound by 3-4db. As stated before it doesn't seem like much but the way the decibel system works that is a significant reduction in sound. If I was driving around town muffs are now unnecessary. On the highway I still will wear them. Only now because of the drivetrain whine. The engine still isn't too bad at wide open but that howl from the drivetrain wears on your ears after a while.
I plan on insulating my cab in the near future also. That should really help with the drivetrain noise but I'm not expecting any miracles.
welldigger
Benton LA
Probably not. It won't fit around the muffler and it really doesn't look bad without it. Once everything is painted it really won't be noticeable. But nothing is set in stone yet.
welldigger
Benton LA
True, making one would be easy enough. But honestly with the muffler there I think a big shroud would look gaudy. I prefer a much simpler clean look. Not to mention where the stack comes out on the deuce I can't really see how you would touch it. My shroud was mounted up pretty high already for some reason and I have never burned myself on it. Of course now that I bragged on myself thats the first thing I'm gonna do lol.
ducer
Ober, indiana
With the large walker muffler I can have a normal conversation at highway speeds. But boy do you sure notice other noises in the truck!
Nothing I need hearing protection for though. And yes it is a flow through design and it seems built in resionator also.
Denny
brianp454
12
Portland, OR
Here's my summary of available mufflers:
Manufacturer
Part Number
Inlet
Outlet
Body Dia.
Body Length
Overall Length
Price
Notes
Aero Exhaust Turbine
AT3535
3.5
3.5
20
$ 100
Straight thru design twist baffle, polished stainless
AT3535XL
3.5
3.5
$ 120
Dynomax Race Bullet
24247
3.5
3.5
16.5
$ 70
Glass-wrap perforated tube, stainless
Dynomax Ultra Flo
17224
3.5
3.5
$ 75
FLO-PRO Twister F4
41288
3.5
3.5
$ 60
Spiral design
FLO-PRO Twister F4
41788
3.5
3.5
23
Spiral design
FLO-PRO Twister F5
51288
3.5
3.5
$ 72
Spiral design
FLO-PRO Twister F5
51788
3.5
3.5
23
Spiral design
Flowmaster Pro Series
13512100
3.5
3.5
19
$ 150
Straight thru design, stainless
13516100
3.5
3.5
$ 180
Moroso
94052
3.5
3.5
$ 60
Straight-through baffled, steel
Moroso
94056
3.5
3.5
$ 106
Straight-through baffled, stainless steel, olished
Patriot Exhaust
H3840
3.5
3.5
N/A
N/A
12.5
$ 36
Insert, louvered core
Patriot Exhaust
H3843
3.5
3.5
N/A
N/A
11
$ 21
Insert, auger design
Walker RV \ Donaldson
? \ M070050
3.5
3.5
$ 50
Perforated tube
21470 \ M070028
3.5
3.5
19.75
$ 50
Perforated tube, Replaces Part Number M353570
peashooter
209
Hanover, minnesota
Just a quick correction on the above Donaldson M070028 spec (I have this one) its body lengty is 14" and overall is 19-3/4". Thanks for putting the comparison together Brian!
https://dynamic.donaldson.com/webc/WebStore/search/item_detail.html?section=10210&item=23070
Inlet
Diameter:
3.50 Inches (89
MM)
Outlet
Diameter:
3.50 Inches (89
MM)
Body
Diameter:
7.00 Inches (178 MM)
Body Length: 14.00 Inches (356 MM)
Overall
Length:
19.75 Inches (502
MM)
Rated Flow
LR:
719.00 CFM (50.80 CMM)
Rated Flow
MR:
1017.00 CFM
(177.80 CMM)
Rated Flow
HR:
1245.00 CFM (25.40
CMM)
Back Press
LR:
1.00 In Hg (25.40
MM Hg)
Back Press
MR:
2.00 In Hg (50.80
MM Hg)
Back Press
HR:
3.00 In Hg (76.20
MM Hg)
Attenuation: 10-15
dBA
Primary
Application:
OFF ROAD
APPLICATIONS
Product Type
Description:
MUFFLER, ROUND,
STYLE 1
Price Type: E
brianp454
12
Portland, OR
You're welcome peashooer! The only thing I have against the smaller Donaldson is a concern about how restrictive it is. Can anyone speak to the design details of the short Donaldson? Does it have an obstruction inline or is it really a straight-thru perforated tube (is what they publish really true)?
peashooter
209
Hanover, minnesota
I don't have pics but I remember a dome shaped obstruction in it (so not straight through unobstructed). It wasn't a total block though, but enough to deflect the sound. I'm pretty fussy and I think it's a very quality muffler that installed without modification.... But I haven't seen all the others either so do your homework (as brianp454 obviously is) if you are in the market for one. I just really wanted to stay away from the giant walker muffler and glass packs.
