Lonesome715
- 25
- 38
- Columbus, GA
That is my biggest hang up. In order to make mine look good and adress the under side issues, I have to get rid of all th eunder coating. Not a simple task.
Thanks for the props Don,And That's not me! My hair is gray and Im not that goodlooking!Ray the tractor looks factory new. Who is that in pic #1 with the red oxide gun...? Cant be you unless they just lowered your ears recently..? How much weight do you think the tractor can pull with a full load..?
Ah! The name! I have one in mind but will wait to reveal it until it is Stenciled on!Looking good as always Ray. 95 degrees, must be nice. Whats the tractors name..? Since it will be hauling the "Tage Mahal "around it better be something cool. Any ideas..?
You will have to thin the primer as recommended if Yor spraying from a gun,i used cans.How was the primer to spray on? I have heard some of the red primer is real thick and you either have to thin it down to almost water like or get a special gun just for that type of red primer.
