Deuce road tractor conversion
RAYZER
59
sanford/florida
Ray after looking at this build thread I can't believe you let me drive this truck! I can tell you it drives perfect, what a sweet truck.
Im glad you were able to stop by and visit Pat! And It was my pleasure to have you drive the tractor to sonny's for some tasty bbq!
Then you went right home and bought a deuce!:D
muthkw25
740
Canton, PA
Ray, what was the hardest part about your tractor build? Was it mounting and pluming the extra tank? Do you have a switch on the dash that lets you select the tank you want or is it all connected to the one on the right?
RAYZER
59
sanford/florida
I think the hardest part of the build had to be all the cosmetics, prep, bodywork, paint, disasembly and reassembly.
The duel tank setup works like this:the origional main tank only supplies the fuel system, the added tank holds my alternative fuel and transfers over via its intank pump to the origional main tank, this allows me to mix in the main tank, the switch is hidden.
Dipstick
1,268
Effort PA
looks great. I want to build a single axle deuce tractor.
I like the single axle Deuce tractor concept myself. The only problem is the 11,000 lb. spring limit when using front springs on the rear of a bobber. I wonder if you could have a spring shop add a few leafs to them or use the front springs from a 5 ton mounted to the stock Deuce rear? Does anyone know what the dimensions of a 5 tons front springs are?
Oh, and Rayzer......nice job man!!!
Dipstick
1,268
Effort PA
Thank you Rayzer and Digger. Roads in N.J. are not the smoothest. My rear axle does bounce a bit on the rough patches. On some civi trucks they use a helper spring that is mounted to the top of the main spring stack, but only contacts frame mounted pads under heavy loads. When unloaded the main springs do all the work. I was thinking along the lines of pulling an equipment trailer someday or having a bomb type hoist frame made. I have read here that bobbed Deuces don't have much weight carrying ability. My truck has a surprisingly high 5,200 pounds on the rear unloaded. I'm sure the dropside bed adds a lot. They are hefty in construction.
welldigger
Benton LA
How about 5 ton front springs for a single rear axle set up ?
Well if you want your kidneys beat to death then yes they would work. If you wanted to go with leaf springs then I would think the leaves off of a civy 2-3 ton truck with overload springs would be the way to go. The ride without a load will still be pretty rough with no weight on the back. But, it might be bearable that way.
welldigger
Benton LA
I don't think it would be that bad ? If the 2.5 fronts aren't enough, I can't see 5 ton fronts riding like bricks. I have never tried this either. Guys do it on bobbed 5 tons with no severe issues. Of not why couldn't you add airbags to the 2.5 ton springs ? Like helpers. It's done all the time. Won't be a factory MV look, but would work and is adjustable. Jim
With a trailer and a load 5 ton springs might not be horrible. Once you go bobtail its gonna be a whole different animal. With no weight on the rear end it will ride like a brick and the rear axle will bounce badly when going over bumps.
I'll admit after building a bobber with full air ride rear suspension leaf springs seem so inferior in every way. The ride is amazing with air bags and the weight capacity is much higher than even 5 ton springs. Even unloaded the air ride doesn't jar you around when hitting bumps.
RAYZER
59
sanford/florida
The 5th wheel weights 900 lbs, ramps about 100 lbs, walking plate about 75lbs and behind the cab spare tire carrier about 200 lbs.
Dipstick
1,268
Effort PA
Digger, I am considering everyone's suggestions and yours is certainly interesting. Do you have any pictures and details on the air bag installation? I'd love to find out more. Thanks!
Dipstick
1,268
Effort PA
I'd like to get the measurements on them. I bet they're wider than 2.5 inches. I probably wouldn't be able to use the stock Deuce axle mounting hardware. I have a friend Glenn who owns a 900 series 5 ton. I should ask Glenn to measure his springs for me. He's always been helpful.
Dipstick
1,268
Effort PA
That's another good idea. I wonder if heavier springs would control axle hop better? I hit some pretty bad washboard road surfaces here in NJ and boy do my heavy, dueled Firestone T-831 tires bounce around. I worry about stuff breaking. I wonder where you could get those helper air bags?
Dipstick
1,268
Effort PA
That's really no too bad. I bet my 8 ft. dropside bed weighs as much if not more. Like your build and trailer by the way.
welldigger
Benton LA
No I wish I did. Me and mark both broke our phones before I put a thread up about the truck. So alls I posted was a few completed photos. I think I have a few photos of the freightliner suspension we used.
Dipstick
1,268
Effort PA
Just knowing you used a Freightliner suspension helps. I would love to see the pictures of the air suspension if you can post them or send them to me. The truck must look weird when the bags are deflated. Way down in the rear. I wonder how the air springs would work off-road?
