therealquaid
- 102
- 33
- California
Thanks for those links!A web search comes up with 10x335, and looking at Oshkosh's web page, MRAP Wheel / Rim - Oshkosh Equipment , they also list it as 10x335.
If beadlock is important, you might consider this: MRAP 20' ALUMINUM RIM | WESTERN CANADIAN ROCKWELL INC
WCR has sold adapter plates in the past. I've never bought from them, so I can't say anything about dealing with them.
I understand now that the reason the MRAP wheel fits the Deuce is because that 10x335 bolt pattern can be adapted for the 2.5ton axle, whereas all the rims with zero offset that I found have a 10x11.25” (10x285) what they are referring to as “commercial semi truck bolt pattern”.
So it seems that to have a gnarly truck with hydraulic assisted power-steering and the capability of using very low psi (both desirable traits in rough terrain and sand) the only wheel to fit a Deuce with close to zero offset and beadlocks is the m1076 PLS trailer rim. Of course a lift in order to avoid the pitman arm/power steering box might also allow for using a rim without zero offset like the MRAP you just suggested.
This rim I sent in post #76 almost fit the bill but the bolt pattern confirms it is not a m1076 and would not fit the Deuce with adapters…
20×10 TRLR wheel army trailer | Military Tires
TRLR wheel assembly, MFR:20076, 20×10, max load:9000 lb., PN:05-15393-00-450, Tubeless, DOT “T” max pressure 87 psi Positive Off
I wish I knew this at the time you sold your set @montaillou
