mooresM35A2
- 0
- 16
- Madison County IL
you guys should take a look at these!
I've tried that before but the problem is when you pull with the boom you're pulling too high on the machine. I tends to just push the front deeper while raising the back. It will work if you can rest the bucket on solid ground so you can lift the front while you pull.ya that would have worked hook a cable or two to the bucket then through a couple snatch blocks to some big trees and back to the excavator and use the boom as a winch no need to get anything else stuck that way i like it doc if you need more pull just add snatch more snatch blocks
