deuce w/ hiab 950 knuckleboom
BFR
Rocket Surgeon
2,330
42
North Georgia
One of the lift cylinders leaks and there is a leak in the swivel. I plan to replace the o-rings in the swivel and the hydraulic lines that run from the swivel up the boom while I have them off.
We ran the crane off of the skidsteer's hydraulic circuit to unfold it/make a tripod so that I could mount it. We had to add a lot of oil to the tractor as full extension w/ the outriggers down emptied it's reservoir (we managed to get 12 gallons into a 5 gallon tank)
gimpyrobb
dumpsterlandingfromorbit!
27,791
791
Cincy Ohio
With the right size reserve tank, there is no need for an oil cooler. My M62 has something like a 65 gal reserve tank!
BFR
Rocket Surgeon
2,330
42
North Georgia
now that looks handy. Is that a standard cargo bed that has just been slid backwards? I would love to see some pics of how it (the crane) is mounted.
cranetruck
94
Meadows of Dan, Virginia
Joel, I see you found a hook. I have a hook that was not rated high enough in the early days and it began to change shape under load, make sure you have a hook rated for you crane...about 8 tons or so, or be mindful about what you lift.
BFR
Rocket Surgeon
2,330
42
North Georgia
According to the manufacturer (crosby) this one (5-s-1) has a working load limit of 5 metric tons (11000 lbs) and is Individually Proof Tested to 2 times the Working Load Limit. Ultimate Load is 5 times the Working Load Limit.
BFR
Rocket Surgeon
2,330
42
North Georgia
The best resource I have found is cranetruck & his posts. Other info on the net seems to be limited to loadcharts and prices.
1,827
Nice, it has a zerk. I need to figure out a way to lube the hook effectively on my hoist block.
Lonesome715
25
Columbus, GA
Thanks. I will see if I can locate his information. Ever since I saw a deuce in another thread with w boom, I have wanted to explore the possibility of installing one for myself.
BFR
Rocket Surgeon
2,330
42
North Georgia
aua
aua
aua
aua
aua
aua
aua
aua
aua
UPS lost my tank.
aua
Just got off the phone with UPS and got a new and improved tracking number. According to this one it is out for delivery today. If it makes it today it will have gone
San Antonio, Texas -> Jackson, Mississippi ->Atlanta, Georgia-> Kansas City, Kansas->Doraville, Georgia -> Atlanta, Georgia-> Gainesville, Georgia in just 19 short days.
