Do I really want a heater?
Whidbey
Hope, IN
Can pop it open with room to spare. While fitting up the empty box, I shortened it enough to make sure it did not interfere while able to fit in 2 heater cores.
Also, the box stands off the fire wall using the standard "L" brackets. The std blower is also offset a bit on the box so there is about 1-1/2 clearance for air pick up off the inside passenger fire wall. I removed the air intake hose ring off the blower air intake.
I did cut about 1/2" off the side of the dash / glove box support bracket for coolant feed clearance on the 1/2" L's on top of the box. 2 "L" brackets are mounted on the blower end to this same support. It does not move.
Ferroequinologist
Resident railroad expert
748
Liberty Hill, SC
Whidbey, is that a 5 ton distrabution box? I notice it is opposite a standard deuce one.
I am also having reservations about installing mine. I know I want a heater for my Alaska trip, but now I'm leaning towards a fuel fired one.
Anyone have a fuel fired heater kit they will trade for a NOS coolent heater kit?
1,135
I chopped the box too and I mouinted mine on the firewall. Had to reverse the fan mount to fit the fresh air hose next to the side access. Got the idea from another forum.
I like your flexible hose a lot more than the factory one.
Storm 51
Just a Grunt
9
Seattle, WA
I'd rather have it and not use it, then not have it and need it.;-)
Bingo! This is your answer.
IF you are planning on having any females (of any age) in you truck in the "cooler" weather (they will call it COLD), you will want a heater. They will be MUCH happier, and thus, so will you.
This is a serious consideration. Think well upon your decision; it may well have long term consequences.
Just my 2cents worth. From experience :wink:
Storm
224
Independence, OH
The black air duct I got from Advanced Auto Parts. About $32.00. And mounting was so tight I had to notch the rubber sleeve on the fan end of the hose to make the turn. Should not be a problem for the normal heater mounting or for those people who think ahead and allow for the hose to make the turn... And yes it is better than the OEM.
I also used it inside the cab.
