Can pop it open with room to spare. While fitting up the empty box, I shortened it enough to make sure it did not interfere while able to fit in 2 heater cores.
Also, the box stands off the fire wall using the standard "L" brackets. The std blower is also offset a bit on the box so there is about 1-1/2 clearance for air pick up off the inside passenger fire wall. I removed the air intake hose ring off the blower air intake.
I did cut about 1/2" off the side of the dash / glove box support bracket for coolant feed clearance on the 1/2" L's on top of the box. 2 "L" brackets are mounted on the blower end to this same support. It does not move.
