Does anyone know where I can find the tailgate strap panel
Gamble
308
Los Angeles, CA
I have looked high and low for these. I can't find one on epay or in any of the forums. Screenshot_20230309_195201.jpg
It's this green panel that fastens to the tailgate and has the straps mounted to it. Please let me know if anyone has one or can locate one.
juanprado
2,805
Metairie/La (N'awlins)
I know they set up is to carry the camo netting and pole set up but why was this plate necessary on this model that I believe is a tow missile model.
juanprado
2,805
Looks like it is for a different purpose to carry a portable folding tripod for the tow missle launcher instead of the camo net set up.
Maybe is also removable and used as a base for the tripod and launcher on sand and soft soil? Swag
BLK HMMWV
453
Pasadena California
I thought the tripod mounted inside.
My tailgate just had loops mounted directly to it.
Tripod mounting plate was attached directly to side of left fender well.
Locking ring that attached T&E to tripod head held tripod in place.
I've seen camo netting attached to rear tailgate using footman loops and straps.
GTUnit
152
CA
Actually the panel I have is not the one OP posted. Its the one in these photos. From a M1167.Anyone know what this variation is for?
The panel is curved and wraps around the cargo hatch when flipped up.
42bd418f-5dba-44d3-a1c8-1c21ff9608a8.jpg6d180bb4-cabb-43e4-a01f-aac89ff56bd2.jpgefd22b03-f728-4a8a-88e2-7999cdb894d7.jpg
  • Like
Reactions: OBX
BLK HMMWV
453
Pasadena California
Never seen one of those before.
From the antenna protector above the antenna hole your truck was a TOW variant.
A later variant then mine.
Perhaps they stowed a ground tripod on that.
My guess would be the Camo netting and support poles.
  • Like
Reactions: OBX
Crapgame
320
Navarre, FL
I believe SOP was to carry the entire ground mount parts for the M220 TOW system in case the HMMWV goes mammaries vertical you can still accomplish the mission. The USMC MG Section Weapons Carriers carried the M3 Tripods for the M2HB .50BMG and Mk19 40mm in the slant's cargo bed even though the weapon system was mounted in the turret.
Note: During Gulf War 1, SF ODAs inserted with ground mount M220 TOW systems to surveil the MSRs with the day/night tracker as well as use it for defense against enemy armored vehicle. The tripod to M220 TOW is surpisingly light. Lighter than the steel/brass bipod we had to hump for the M29A1 then later on M252 81mm Mortars.
Crapgame
320
Navarre, FL
My theory: with the camo net and pole bag strapped to the gate, on a truck with A2 (or A1) airlift bumper installed, you can't lower the tail gate without unstrapping the net and poles, first.
This bracket looks like you can unfasten the center 2in strap assy and the net/poles or M22o TOW Tripod will pivot out enough to clear the Airlift Bumper. This is even more important in the armored truck, we could reach our shit in the cargo bed from the crew compartment in the M1025 but the M11xx armored trucks have that armored c pillar divider.
papakb
1,186
San Jose, Ca
This parts truck just showed up in a listing about: Introduction & warning in this forum. Isn't that the strap rack your looking for? You might PM the owner since he says he's going to scrap some of it.
