Engine repair or swap to LDS?
DaneGer21
1,162
Creston, Ohio
More good news! Front 3 pistons are all in spec.
Going to break down the heads and take them in for vatting, magnaflux, resurfacing .001", etc.
What valve spring compressor does everyone recommend? Most seem to be for small motors
Hopefully a resurface of .001 would be awesome/ideal; fingers crossed!
Make sure they note how much material it actual takes!
Gypsyman
741
Quincy, FL
If this hasn't already been posted it's an old thread and a long read but lots of great information.
Welder1
160
Albany Ga
I checked it with a straight edge, and it looks flat, but we'll see. Seems as I remember .005 is the limit and I see no marking indicating it was previously machined.
I would not get too concerned about the .005" limit. Focus on getting the seal area for the combustion chamber to clean up. The last set I had done we took off .010" didn't cause any issues. The valves still had some recess.
Eddie
ldmack3
1,740
N. Central Idaho
Thanks. TONS of info. So many opinions that at present after I get the heads done I will replace the intake rockers as consensus seems this is a big part of the increased power. I'm not trying to build a screamer deuce, just more power for the hills and lower EGT. I will also change the air cleaner to either an A3 or 5 ton. Injectors are 2 hole and tested "like new" they said.
My first deuce so all suggestions appreciated!
DaneGer21
1,162
Creston, Ohio
Where are people finding the rockers? Just curious
ldmack3
1,740
N. Central Idaho
Ok got the valves out and will be taking the heads in soon for magnaflux, vatting and resurfacing.
The back side of my intake valves have heavy carbon deposits on them. Since the only let in air from the turbo where are the deposits coming from? Exhaust is clean. All are the same.
Last valve job I did was about 1968 on a '62 Buick. Had nothing like this.
Probably should have thought this trough a little more before posting. Worn valve guides letting oil in? Intake would let it in, exhaust would blow it out.
rustystud
3,280
Woodinville, Washington
View attachment 876452View attachment 876453
Your correct about the valve guides letting in oil. That is the classic look of leaking valve guides. Remember it's hot in that engine, so any oil will immediately start to "cake" on any surface it is not removed from. Since only air is coming in from the intake valve it will not remove the caked-on oil.
ldmack3
1,740
N. Central Idaho
Since the exhaust is clean would you recommend only replacing the intake guides? Intake valve stems are close to the limit so I was planning on reusing them. I don't have a .0001 mic so not certain how close. Bad idea?
