Feeler: Turbo kit for the Diesels
jatonka
Ephratah, New York
Haven't heard from Dr. Fosterlately. JWaller is for real, He may be doing some turbo experimentation. Check with Cranetruck, He's our engineer when it comes to electrics and engines. JT
jwaller
20
Columbia, SC
nope, I spent good money and time to have flanges made and Dr Foster disappeared. I made my own turbo that used a different compressor wheel only to find out that is was only slightly better than the Stock D turbo. all of it was for nothing.
if you have an endless supply of money a very good turbo could be had for these motors but nobody will spend more on a turbo than they did for their truck so I stopped wasting my time on the project.
m-35tom
230
eldersburg maryland
'dr foster' was just dreaming and probably or almost certainly didn't have a deuce and did not know much about them. much of what i read from him was just wrong. you cannot just put a different turbo on and have twice the power, especially at the same boost. it's the same addage that works for any engine, 'horsepower lives in the heads'.
merlot566jka
ID or TX or OK
I agree. I read most of his threads. It was clear he didn't know anything about diesels, compression engines or deuces. Whatever the case, I'm interested in finding a new turbo for my deuce. Not a stocker turbo either.
After further searching, I have come to the realization that the deuce turbos have a T-6 flange. And T-6 to T-4/T-3/ etc adaptors already exist.
rustystud
3,394
Woodinville, Washington
Use the International Harvester turbo #3LM466. This is the turbo that the tractor racing guy said to use. Check out the posts on "LDT vrs LDS engines . The last three pages has some good info.
m-35tom
230
eldersburg maryland
net says this turbo is good for applications up to 200 hp? and no wastegate?
JasonS
202
Eastern SD
Does the 3LM466 have the waste gate that requires moving the starter to the other side?
The LDS wastegate turbo clears both the stock and gear reduction starters. I can say with reasonable certainty that the 3LM466 is physically smaller than the LDS wastegate turbo and should fit fine. It may even be a smaller flange size.
JasonS
202
Eastern SD
How do you mount an automotive exhaust to that turbo? Looks like it was designed to mate with a tractor's stack.
red
26
Eagle Mountain/Utah
For turbo options has anyone tried the holset hx35? Reading its turbo map and doing the math it matches very well for a 200hp goal.
200hp goal
***Mass flow 27psi
***MAP 30.9
***Pressure ratio 2.25
***S200, hx35.
red
26
Eagle Mountain/Utah
Upside is the hx35 is common and cheap, externally waste gated so we can keep the pressure down. Flows far more efficiently than any of the stock turbo options which will reduce egt's.
Downsides are it has the ability to over boost the multifuel if you don't adjust the waste gate correctly. It is a T3 flange, smaller than our stock T6, there are reasonably priced adapters but that does make for a restriction.
