Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
So it turns out that there is enough room in the sub-panel to install these directly and don't need a separate enclosure. I will post some photo's once I get them installed.
so this looks useful, but these units only monitor one phase (or leg if you prefer) so you need 2 and then you must add the results. seems there would be a similar unit that looks at both legs and in the process also at the sum of those legs for the total of those loads as well?
I do have two, one for each leg. Mostly I want these to ensure that the legs are equally loaded. I have already powered everything from the generator that I want to power and it come out to about 75%, so I am not too worried about calculating total load.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
