Fixing the 1998 HMMWV
mrandig
119
33
Houston, TX
Heater / Defroster Duct Removal.
Based on the abject failures of earlier this week and last, I decided to focus less on taking pictures. Why bother if it's not going to work out, am I right?
That being said, one thing led to another, and now all of the heater and defroster ductwork is being replaced. This is a good thing, as the cabin would just fill up with dust (sand) anytime either were turned on.
Any pictures I have then are post-mortem, rather than in-process, but I'll explain the best I can.
The first step is to remove the access cover on the passenger side. The fasteners don't quite match what's shown in the manuals, but mine was two bolts at the top right, and one screw at the lower left.
Once the cover is removed, you'll have full access to the entire unit, including both duct assemblies and all of the flex ducts. Obviously, I took this picture after the flex ducts were removed.
The bug sprayer is filled with soapy water, as I like to clean as I go.
The right-hand defroster duct and nozzle are pretty easy going. Just unscrew the lower clamp and wiggle the nozzle out of its channel.
The large heater duct which bridges across the doghouse will need to be removed. For me, this needed to be replaced anyways. Mine didn't have any clamps, so it was just a slip-on/slip-off situation.
Once the heater duct is out of the way, there is a body panel and a retaining strip that will need to be removed from under the windshield frame. There's a total of eight screws inside the cabin, and three bolts in the engine compartment.
Once the body panel is removed, there will be some insulation strips that will also need to removed. In my case, they just fell out, so I didn't need to do much. The question is, how we will put this back together once the time comes to reinstall.
My money is on double sided tape, but we'll see.
20250418-084641-011.jpg.
The left-hand duct and nozzle are almost more trouble than it's worth. From the doghouse side, pulling on the duct will get you a big handful of shredded duct work, but removal of the nozzle requires access from behind the dash.
You're going to need to drop the steering column for this part. Also, I had already managed to break both my turn signal lever and air restriction gauge during my earlier exploits, so be careful.
Once the steering column is dropped, you'll be able to access the retaining pin that holds in the left nozzle. It's still pretty tight to get to, but not impossible.
I ended up using an automotive trim tool and was able to get the retaining pin out, in mostly useable condition, for re-installation.
Retaining pin removed.
Considering how over-done, over-thought, and over-priced everything else is, it's like they got close to the end of building this truck and just said screw it. "We'll just use the interior trim pieces from a Chevy Cruze".
Left duct finally removed. It's a funny process getting this nozzle out, as you have to turn, twist, push, and then pull a few times, but eventually it does come out. Supposedly it should be turned clockwise to install, counterclockwise to remove. Supposedly.
Once everything is cleaned up and organized, we'll start putting in the new parts; hopefully later today. More updates to follow...
mrandig
119
33
Houston, TX
None of this was on my original to-do list.
Actually, it looks worse than it is. With some luck and a little bit of time, this should be all back together by tomorrow.
A few updates to follow shortly...
mrandig
119
33
Houston, TX
Replaced the fuel gauge with a Faria one this evening. This was absolutely one of the issues that was causing problems.
Notice that it's pegged to the far right with power and ground connected, but without the sending unit attached. This is exactly what this gauge should be doing.
It's frustrating however that this gauge is scratched right from the box, but at least it's only cosmetic; we'll deal with that next week.
The new gauge seems to be reading pretty high, but the tank looked very full also. I'm not sure if this reading is correct, but at least now, if there is an issue, I can focus solely on the fuel sender.
While I was changing out the fuel gauge, I also replaced the gaskets on the dash lights. I didn't take a picture here, but it definitely makes a difference with the gauge illumination.
All done with the dash and gauges. We'll get this back in for good once the flex ducts are installed tomorrow.
mrandig
119
33
Houston, TX
For my last item this evening, I want to knock out the brake warning indicator that has been giving me problems. Actually, it hasn't been giving me anything, which is why I need to change it.
Brake warning indicator.
Here's my problem-child. I already removed the air restriction indictor so I could gain access to the lamp wiring.
Warning light disconnected.
Disconnecting the lamp and testing it is a little tricky, as there's not really room for two hands, but it's possible. Looking for a full 24v on this circuit with the parking brake engaged. Alternately, instead of engaging the parking brake, I could've grounded the switch at the proportioning valve, with the same result.
Results are in, and they are correct. We've got 24v when the parking brake is engaged, 0v when it's not.
There's nothing wrong here except for a bad light.
Light Replacement.
This was another piece that was tricky to replace but worked out in the end. The space behind this lamp is really narrow, and it's not a matter of reaching up and just plugging in the light.
I ended up sliding the lamp into place from the open dash panel (not shown). There's a channel behind the dash face, and the light can just be slid sideways right-to-left until it's in the correct location. It's just two self-tapping screws that hold it in place. The connections are hard to make with one hand, but it just takes a little patience.
Success!
mrandig
119
33
Houston, TX
This weekend is going to be lit. As my youngsters would say...
It's Easter weekend and I've got a box of cleaner and radiator paint.
They even gave me coupons. I can get ground beef for life, discounts on deodorant and ED pills. Interesting choice of combinations, but I guess I can see how at least two of those go together.
Once the flex ducts are replaced and the interior has been re-installed, we'll come back to this.
mrandig
119
33
Houston, TX
Just wanted to follow up on an earlier post to this thread. Way back when, in post #6, I had questions regarding the driver's side mirror assembly.
This mirror has a low mounting point, rather than mounting at an equal height to the passenger side. The latter (equal height) configuration seems to be more common, and this truck does have those riv-nuts installed also (damaged however). My eyeballs aren't calibrated, but it looks like it sits about 6" lower.
I've researched this to the point that I don't even remember where I looked or what I've come up with as a result.
The -24P gives me 5 different listings for mirrors; none are specific to an M1123 A2 (UOC NNN). The -24P does say however, that the mirror currently installed is the correct part number for a "lower mount" mirror.
Neither the -20 nor -24P are particularly clear on how this is supposed to look once installed. The -10 however, does have this...
So, back to my original question - does this mirror look like it's installed correctly?
Thanks in advance.
I was never able to fully get my question about the lowered driver's mirror sorted out, so I just decided to replace. Enough time has already been wasted, and I didn't want to lose any more.
The new driver's mirror is black instead of green, but it is pretty. The was definitely something that was cattywampus (incorrect) with the first one.
Here's the original:
The new mirror sits in the same "low" position, but it now looks intentional. It doesn't have to be adjusted in all sorts of weird angles to be useable, like before.
To be totally honest, the original riv-nuts in the frame are wasted, so it was just easier to leave the mirror in the position it was at. Otherwise, I probably would have raised the driver's mirror to be at the same height as the passenger's.
Before:
After:
I'll take the cover and protective packaging off it at some point. It's not like I'm going anywhere in this truck over the next few days. It's just one less thing to get scratched at the moment.
Check off another task as completed.
mrandig
119
33
Houston, TX
Most of the tasks I'd been recording over the last day or so, were done while also working on the heater / defrost flex ducts. Needless to say, there's a few steps to getting these reconditioned, before even trying to get them back into the truck.
With all of the flex duct removed, the first thing was to figure out the correct length(s) I was going to need.
Next, I needed to remove the old nozzles, as these will be re-used. The hose is glued on, but you can use a peeling action to get these off easily.
With the old hose removed, clean the nozzle ends to remove any dirt, debris or loose glue.
I'm going to use some adhesive sealant RTV. It happens to be what I have around, but also seems to be similar to what was originally specified. This particular type of RTV (#80080) is a general adhesive; it's not for engine use. Basically, it's glue for adults.
You probably won't need such a big tube, or the caulking gun, but it is fun to have. If I got my wife a vacuum for her birthday, she'd probably be pretty p****d-off. If I got a new caulking gun with all the fancy features for my birthday, I'd actually be pretty thrilled.
There doesn't need to be much glue, as the connection will be very tight. A thin bead should be fine.
Once applied, gently twist the new hose over the nozzle. As I went, I kept turning the hose clockwise to install, but I'm sure direction doesn't matter.
Once the hose is fully seated, the assembly will need to cure for 24hrs. For a little added security here, I also added a zip tie.
Here's everything completed.
Just as a side note, if you don't have a pair of medical scissors, get some. Steal some if you need to. They're absolutely one of the best tools that I own. Any cutting I had to do here was with these, and they're fearless.
Any finally, the clamps go off the ultrasonic cleaning bath.
We'll catch back up on this task once everything has had a chance to cure, and once I'm convinced it's not going to fall apart during installation.
