majoday
- 154
- 33
- Bloomburg,TX
What is the best way to proceed.?I removed # 1, the bottom looks great, all of the top is rusted. The fuel system was terribly contaminated.
What are Stickies? I have been reading the Generators Forum and have seen pictures. The info is great. I copied and pasted on MS Word some info.Your honkin! Have you read the Stickies posted in the Generator forum? Great info there.
I did not order the 14D151K MOV, the in-USA appears to be out of stock. I will run the motor soon , but pull the fuse on Pin 8 to disable the gen head. In the mean time, i will find the MOV.What are Stickies? I have been reading the Generators Forum and have seen pictures. The info is great. I copied and pasted on MS Word some info.
The MOV protects the voltage regulator not the gen head. So I don't think pulling the fuse to the gen head will actually help.I did not order the 14D151K MOV, the in-USA appears to be out of stock. I will run the motor soon , but pull the fuse on Pin 8 to disable the gen head. In the mean time, i will find the MOV.
Ordered them. Thanks for the guidance. I did not know anything about them.The MOV protects the voltage regulator not the gen head. So I don't think pulling the fuse to the gen head will actually help.
I might be able to send one, when I bought my MOV's 2 years ago I got a pack of them.
Amazon.com: 10pcs varistor 14D151K 150V piezoresistor 14D151 : Industrial & Scientific
Amazon.com: 10pcs varistor 14D151K 150V piezoresistor 14D151 : Industrial & Scientificwww.amazon.com
I found my purchase link, apparently they are FengHui.
You mentioned you wanted made in USA though.
EDIT: I did a quick search and Mouser has 7,000 ready to ship. Brand Bourns.
I would trust them from Mouser personally.
Ordered them from MOUSER Tomorrow fuel and priming when the parts arrive.I did not order the 14D151K MOV, the in-USA appears to be out of stock. I will run the motor soon , but pull the fuse on Pin 8 to disable the gen head. In the mean time, i will find the MOV.
Thank you! I ordered 10!!The MOV protects the voltage regulator not the gen head. So I don't think pulling the fuse to the gen head will actually help.
