- 7,018
- 9,701
- 113
- Papalote, TX
That screen should not be serviced in the field, ONLY if you were positive it was plugged and as a final hail Mary should you remove that screen, if you are getting fuel into the body of the pump that screen is not what is keeping your truck from running.
It is almost impossible in the field to be sanitary enough to assure something/anything does not get behind that screen, and if it does ether the pump or an injector will fail.
