Fuel delivery issue M1123 ,Crank no start .....help?!
Mogman
10,496
Papalote, TX
I normally would not say that the fuel must be changed because I have never seen diesel gum up things, I have a little dozer I just brought back to life after almost ten years sitting in a pasture, fuel is just as clear and clean as it started, good thing too as there was about 20 gallons in it, it runs fine.
BUT after your experience where the JP has gummed things up as evidence of the stuck linkage confirms I would definitely change fuel (and filters again) before continuing, without evidence of corrosion I would not give up just yet (nothing to loose at this point anyway but time)
Then if you did "give up" I would also change filters again before installing a new IP and possibly drop the tank for a thorough cleaning, filters are cheap, unfortunately because of the crack heads at AMG not so easy to change.
Maxjeep1
1,930
Las Vegas Nevada
I did add new fuel to old fuel and put diesel Kleen in it. Fuel coming out water separator valve looks clean and it looks good coming out of filter canister. I was thinking that if I can get it freed up it should be able to burn it. My m1123 sat for 20 years and not a problem with it
Maxjeep1
1,930
Las Vegas Nevada
I have been letting it soak in diesel Kleen and I have been turning it over a few times a day. I drained it out of ip and put fresh cleaner in. I put everything back together and I cranked on it for 12 seconds or so and I now have fuel coming out of the return line. It filled up my clear line in a short time. I will keep messing with it and tomorrow I will put fresh fuel in it and try to bleed injection lines. I have with help been able to fix 2 pretty big issues with the ip.
Mogman
10,496
Papalote, TX
Sounds good! IF you start getting fuel out of the injection lines, pull the power to the IP and make sure it stops while cranking before tightening up the lines.
Humveegene
Racine,WI
Well ladies and gentlemen It’s time to start playing taps for my injector pump. Finally got it open and this is what I found after sucking all the fuel out that was not getting to the injectors. My hats off to the wonderful last mechanic at Barstow that must’ve lost two bolts to connect the throttle bracket to the IP And decided to improvise with longer ones.Time to start shopping.
Mogman
10,496
Papalote, TX
Sorry man,,, THAT SUCKS!!
I guess the question now is did it jam up down in the governor housing and bust a key in the cam gear...
Actually that piece you have in your hand looks like it came out of the gov. housing.
EDIT, but what an opportunity for us ALL to learn!!
Humveegene
Racine,WI
The black piece is part of the wiring connector in the cover that broke off I don’t think that got in there but there are some metal filings in the chamber.
Milcommoguy
2,402
Rosamond, CA
This is a different rig, PUMP and Solider..............
What a F ing MESS. That sucks. It could be salvage BUT best to bite the bullet on a new / rebuild IP. That part is the insulation plastic off the solenoid.
Question ??? Can you see the flywheel vanes spin when cranking?
Not a fun day to run into this. I feel for YA man, CAMO
Mogman
10,496
Papalote, TX
I was afraid to ask him to spin it again..Maybe by hand, do not test the fates!!
Milcommoguy
2,402
Rosamond, CA
There's a gummed up pump in Vegas (Maxjeep) and this latest one (Humveegene) with the throttle cable bracket bolts punched thur the housing, add with a broken solenoid power feed thru post.
Buying tip of the week. Non runners... RUN AWAY, CAMO
Mogman
10,496
Papalote, TX
I may give it a try….live dangerously and take chances right…and they trusted me with thermal Nuclear weapons !
Well if you happened to have disturbed the pieces that were broken off in the pump and it seizes while you are cranking it it could shear the camshaft key (If it already hasn't) then you get to take the entire front of the motor apart to fix it, seems like a foolish game of Russian Roulette to me, I hope you did not do that with the nukes....
Maxjeep1
1,930
Las Vegas Nevada
I just called a local rebuilder that was listed on Stanadyne website. He said anywhere from 1,500 to 5,000 to rebuild mine. I told him that a brand new pump was 2,100 and he said well you would be saving 600.00
I would never pay that to have mine rebuilt. Rebuild kit is less than 100.00 from what I have seen.
Mogman
10,496
Papalote, TX
Keep looking, the shop in Victoria TX, one of the only shops around here that still rebuilds the DB2 charges 7-900 which is still high, the diesel shop in Corpus said they can get one exchange for 650.
Yes what they charge is absurd, not that much to them but because it is one of those magical things they can charge out the wazoo
Milcommoguy
2,402
Rosamond, CA
IMO... the IP is not that big of a deal. The magic trick is revealed by studying up, manuals, TM's, exploded views, UTubes, understand all the bits. Couple of special tools ? a clean and organized bench. Not much more than the old days of a carburetor rebuilds. Remember those? Check balls rolling around HAHA.
Labor / skill to rebuild...not to bad. After the rebuild... IP Calibration of fuel delivery, timing and governor set up. That machine is the big ticket money maker that as to be paid for if one wants it right.
With increased sales and a bit lower bids dollars to win the surplus HMMWV you always wanted... this MAY be a good deal? I count 75 units a week up for bid. Check me on that if i missed something, but it's a LOT.
For 50 years a "Junk yard Dog" here. Surplus uses to be a good deal. It added to the quality of all my hobbies. Got it for "Pennies on the dollar" we would say to justify the item and to hold off the boss. LOL. Jump forward and all the increases of damm near everything...wages, transportation shipping, overhead and the list goes on and on... putting a squeeze on the "good deal for pennies" Part are parts and prices are way up uP UP. So are Big Mac's.
Turning wrenches in the driveway is about the only way... HumV, fun, and hobby is going to work. Save your pennies for parts and fuel.
Sticker shock parts, shocking bids and government surplus...Didn't uses to be that way,
Just another storytime and bandwidth burner with, CAMO
Back to work.
