The O-rings or the whole nozzle?Memphis Equipment has them for 61 dollars ! good supplier for Military trucks !
The "LDS465-1 Troubleshooting Manual" shows the same hexagonal flame heater nozzle in a flame heater system with the solenoids. I suspect that it needs the solenoid to not leak.Mine was leaking through from the return line which has slight pressure when the engine is running . I installed a check valve on the return side and a solenoid valve on the pressure inlet side to be sure to control the leaking . It now works fine. New valve design is great with no o rings but sucks that it leaks through !!!![]()
What did you use for a solenoid valve? I want to keep my flame heater working, I use it here in Michigan. I rebuilt my original style nozzle a month or so ago, but I suspect a leak. I've got stuff leaking out at the joint between the intake manifold and the head, and running down the block. Still don't see how this thing can fill the crankcase, any fuel is leaking into the intake manifold, yes? If the engine is running, it should be pulled into the cylinders, correct?Mine was leaking through from the return line which has slight pressure when the engine is running . I installed a check valve on the return side and a solenoid valve on the pressure inlet side to be sure to control the leaking . It now works fine. New valve design is great with no o rings but sucks that it leaks through !!!![]()
deathrowdave, any chance you can put a picture up of your setup?I used a 24 volt solenoid 1/8 inch NPT on the discharge ( Small Tube ) and check valve in the return side ( Large Tube ) 1/4 inch NPT. These can both be found on Egay !!!
