peashooter
- 204
- 63
- Hanover, minnesota
Working strange shifts again !!!! I will post pictures ASAP., latter this week on off day.
No problem Deathrowdave, let me ask you this then. What direction does the check valve on the return line need to be in? I thought I read somewhere that the small line (higher pressure line from the pump) just is used to pilot activate the valve and that the return line is what supplies fuel... if thats the case the check valve would be mounted one way. But when I hooked up my new (and leaking) flame heater valve, i watched fuel go out the back of the valve and up the return line (so the check valve would need to go in the other direction).
Do I want fuel only coming out of the flame heater nozzle valve going up the return line to the Tee with the injectors, or do I want fuel only going the other direction? thats the only thing I really cant get, I've read conflicting posts.
