Clay James
- 4
- 18
- Reno/NV
I got SAE 50 motor oil from NAPA to put in mine.
The simplest bit of information that should sway you if anything will is that Spicer, the maker of the transmission, says not to use oils with EP additives in their transmissions. GL5/MT1 is full of EP additives.No one has come up with anything remotely credible to change my mind. If your tranny blowed up because of GL-5/MT-1 please post!
Do they recommend the same for the axles?Rockwell, the manufacturer of your T136-21 transfer case states 80w or 90w GL-1 or....
30w, 40w or 50w CD spec oil (diesel motor oil).
Attached is the page from the Rockwell manual.
SAE 50 is a Viscosity Grade. Tells you nothing of what IN the oil, only how well it will flow at TESTED temps.The simplest bit of information that should sway you if anything will is that Spicer, the maker of the transmission, says not to use oils with EP additives in their transmissions. GL5/MT1 is full of EP additives.
Spicer specifically recommends using SAE50 motor oil. SAE50 is the same viscosity as SAE90 gear oil. If you want something a little thinner, use SAE30, or SAE40.
-Chuck
Let's not get too anal here Paul, I said SAE50 motor oil, not SAE50 maple syrup.SAE 50 is a Viscosity Grade. Tells you nothing of what IN the oil, only how well it will flow at TESTED temps.
So you are happy to use SAE 50 maple syrup?
API is what you need to look at. THIS IS WHATS IN THE OIL. The pdf says API CD, CE, SF and SG are acceptable.
The synchronizers are clutches, and rely on the oil making them have a certain amount of friction, for their operation. If you use an oil that is too slippery, the synchronizers will not spin up the gear clusters, and the transmission will grunk. The converse can also have an effect, and make it very hard to force the shifter into gear.I haven't seen a ton of transfer cases, but I cannot imagine what EP additives are going to harm. I used GL-5/MT-1 in every driveline component... diffs, tranny, transfer... nothing has rotted out in over 5 years on the jeep and 3 in the CCKW.
Also, what odd is FOOTNOTE 4: "Do not use Multi-viscosity GL-5 gear oil, axle lube. Is the prohibition on the multi viscosity rating or the GL-5 spec?
They put the oil canisters upside down and above the oil sump level against Hercules's recommendation, they used bobble head valves on gear boxes, transmissions, and differentials, without providing a means for equalizing pressure after cool down. The Army does lots of things that are dumb in the name of expedience. They have different issues than the manufacturers do, so they often go against manufacturer's recommendations. GL-5 is one of those instances.I don't think the Army is dumb enough to put incompatible oil in the drive train, end of life or not. Is there SIGNIFICANT difference in the rebuilt M35s in use NOW vs the rebuilt M35s showing up on GL? Other than the A3 and auto trans, I don't believe so.
The Army says nothing about GL-5 in its lubrication order for the deuce. They talk of using GO which meets MIL-L-2105. GL-5 is a civilian designation, which means nothing to the Army.I agree that way back when GL-5 did have a yellow metal issue. But the MT-1 spec clears that up, and even then the sulfur had to get hot (250F+ hot) before the chemical reaction to make the acid occurred. But like not fully loading an M-16 magazine to prevent misfeeds, that to is ancient history and only comes up when the uninformed bring it up.
Great! If only I could trust that your idea of working fine matched mine. Your experience in that jeep is limited to a single brand of GL-5 blended oil.... over whatever temperature range, and operating conditions, you have decided is fine with you.I have GL-5 in my jeep now for over 3 years. Tranny and transfer. There are plenty of brass bushings and synchro's and they are working fine.
I don't believe I have said anything about the oil the TM says is OK. I have been talking of the oil the MANUFACTURER recommends vs the oil the MANUFACTURER says not to use.If you want to be an 'oil snob' and 'only run what the TM says' then OK, great, have at it... but don't say that GL-5 is wrong, because that's what in use NOW as GO (as per the spec posted above).
Whats kinda funny is that if you got the truck from GL, or any truck released from active inventory, it had GL-5 lube in it. So, since about 1993 IIRC its had GL-5 in it, then you read an outdated TM (again, I cannot find a LO on this site that specifies a GL-1 rated oil) and think that somehow the new maintenance procedures/specs are going to rot out a drive line.I'm still going to stick with GL-1 as long as I can still get it. I don't know if it's got cow pee or TN river mud in it but my trans seems to like it.
That's what the LO calls for. I use the 'SuperTech' brand (Wally Worlds house brand) and its good stuff. I also use the SuperTech oil filters for my 'zuki and the 'SuperTech' oil for all my cars.so Paul,
It will be ok to use my GL5/ MT1 bottles of 80-90w from Wallyworld in my deuce transmission?
