Glow plug removal Mep002a/3
dstang97
33
Clover, SC
Just an update on this thread. I just came up with a crazy idea. I'm going to use the control box and the generator head and make a 3point skid to hook up to the back of my tractor.
Triple Jim
329
North Carolina
Tractor PTOs are normally 540 RPM, and some have a 1,000 RPM option. The PTO generators I've seen have a gearbox or belt drive to get up to 1,800. Two or three V belts with the right size pulleys should work, but you'd have to deal with shafts and bearings, etc.. It would be a project, no doubt.
Guyfang
26,512
Burgkunstadt, Germany
Lots of pig farmers here have PTO driven gen sets for back up. If they lose power in the winter, a barn with 1000 pigs is in trouble. Even in summer, if the temps are high, losing power is big trouble. We set up a power station last year for a guy who had a Biogas power plant, photoelectric on the roof and naturally, an emergency hook up for his 30 KW PTO driven gen set. Wonderful set up. The PTO is simply a cable hook up and away we go!
Chief_919
104
Western NC
Does yanking the swollen glow plug out of the head leave debris in the prechamber?
Sometimes.
depending on how swollen it is often it will be swollen just enough to not pass the threads, but by using one of those tools like I linked to you are pulling back and turning and that will pull it into the threads and basically squeeze it down and cut threads as it goes.
I get 80-85% out intact like that.
The keys are lube the threads well before starting and turn the plug in a slow, steady application of force. Don't go fast, don't jerk it.
That is why those tools are better than just yanking it or twisting with pliers.
